Translation Rules
The translation rules subelement is where the actual translation rules are created. The fields within this element specify the type of translation to be performed, the addition or deletion to be made, and where in the address that change takes place. Translations are not applied to any realm or session agent in this element.
When creating translation rules, first determine the type of translation to perform. The following table lists and describes the three types of number translations.
| Field Value | Description |
| add | This translation type adds a character or string of characters to the address. |
| delete | This translation type deletes a character or string of characters from the address. |
| replace | This translation type replaces a character or string of characters within the address. Replace works by first applying the delete parameter then by applying the add parameter. |
After you set the translation type, you define the string to add or delete. The wildcard term for a string to delete is the at-sign, @. Finally, you specify the character position in the address to make the addition or deletion.
The character position where an add or delete occurs is called an index. The index starts at 0 (immediately before the leftmost character) and increases by 1 for every position to the right you move. In order to specify the final position in an address, use the dollar-sign, $.
To create a translation rule that deletes a string:
Translation Rules for Adding Strings
To create a translation rule that adds a string:
- Enter a descriptive name for this translation in the ID field.
- Enter the string you want to add in the add string field.
- Enter the index of the string insertion in the add-index parameter. If you want to add a string at the end of an number, enter a dollar-sign $ in the add index field.
Translation Rules for Replacing Strings
To create a translation rule that replaces a string:
A string replacement involves deleting a string followed by adding a string in the removed string’s place. The index is not used when replacing a string.- Enter a descriptive name for this translation in the ID field.
- Enter the string you want to delete in the delete string field.
