SIP Request Method Throttling
You can configure throttling mechanisms for SIP INVITEs and REGISTERs using session agent constraints. However, you might want to throttle other types of SIP methods, and for those methods you should use the rate constraints configuration available both in the session constraints (which you then apply to a SIP interface or a realm) and the session agent configurations.
Oracle recommends you use session agent constraints for session-rate INVITE throttling and registration-rate for REGISTER throttling.
For SIP access deployments, you can configure rate constraints for individual method types along with a set of burst and sustain rates. These constraints can help to avoid overloading the core network. In addition, they restrain the load non-INVITE messages use, thus reserving capacity for INVITE-based sessions and Registrations
When you configure SIP request method throttling, you must exercise care because it is possible to reject in-dialog requests. Therefore, Oracle recommends you do NOT configure constraints—although the configuration allows you to and will not produce error messages or warnings if you set them—for the following SIP method types:
  • ACK
  • PRACK
  • BYE
  • INFO
  • REFER
However, the Oracle Communications Session Border Controller is likely to throttle NOTIFY requests despite their being part of a Subscribe dialog.
Therefore, the methods you will most likely configure for throttling are:
  • NOTIFY
  • OPTIONS
  • MESSAGE
  • PUBLISH
  • REGISTER
The Oracle Communications Session Border Controller counts Re-INVITEs and challenged responses against the throttle limit, but does not check to determine if the constraints have been exceeded for either.
You can configure separate constraints—inbound and outbound values for burst and sustain rates—for each different method type you configure. Although you should use session agent constraints (and not rate constraints) for INVITEs, if you also set up rate constraints for INVITEs, then the smallest configured value takes precedence.
About Counters and Statistics
Each rate constraint you configure for a SIP method tracks its own counters. For example, if you configure a rate constraint for the PUBLISH method, the burst and sustain rates you set for it apply only to the PUBLISH method and not to any other methods for which you might set up rate constraints. You can, however, set the burst rate window in the session constraints configuration that will apply to all methods configured as rate constraints.
The Oracle Communications Session Border Controller captures statistics for SIP methods throttled by rate constraints for SIP interfaces and session agents; it does not capture these statistics for the global SIP configuration.
SIP Request Method Throttling Configuration
This section shows you how to set up rate constraints for session constraints (which are then applied to SIP interfaces) and session agents.
To use this feature, you must enable the extra-method-stats parameter in the global SIP configuration.
To set the extra-method-stats parameter in the global SIP configuration:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
    ORACLE(configure)#
  2. Type session-router and press Enter.
    ORACLE(configure)# session-router
    ORACLE(session-router)#
  3. Type sip-config and press Enter.
    ORACLE(session-router)# sip-config
    ORACLE(sip-config)#
    If you are adding this feature to an existing configuration, you need to select the configuration (using the ACLI select command) before making your changes.
  4. extra-method-stats—Set this parameter to enabled.
  5. Save and activate your configuration.
Rate Constraints for SIP Interfaces
To apply rate constraints to SIP interfaces, you need to configure rate constraints in the session constraints configuration and then apply the session constraints to the SIP interface where you want them used.
Note that you need to set up the parent session-constraint configuration to save any rate constraints you configure.
To configure rate constraints:
    ORACLE(configure)#
  3. Type session-constraints and press Enter.
    ORACLE(session-router)# session-constraints
    ORACLE(session-constraints)#
    If you are adding rate constraints to an existing configuration, then you will need to select the configuration you want to edit.
  4. Type rate-constraints and press Enter.
    ORACLE(session-constraints)# rate-constraints
    ORACLE(rate-constraints)#
  5. method—Enter the SIP method name for the method you want to throttle. Although the parameter accepts other values, your entries should come only from the from the following list for the feature to function properly:
    • NOTIFY
    • OPTIONS
    • MESSAGE
    • PUBLISH
    • REGISTER
  6. max-inbound-burst-rate—For the SIP method you set in the methods parameter, enter the number to restrict the inbound burst rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
  7. max-outbound-burst-rate—For the SIP method you set in the methods parameter, enter the number to restrict the outbound burst rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
  8. max-inbound-sustain-rate—For the SIP method you set in the methods parameter, enter the number to restrict the inbound sustain rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
  9. max-outbound-sustain-rate—For the SIP method you set in the methods parameter, enter the number to restrict the outbound sustain rate on the SIP interface where you apply these constraints. The default and minimum value is 0, and the maximum is 999999999.
  10. Save your changes and apply this session constraint and its rate constraint(s) to SIP interfaces.
Applying Session and Rate Constraints to a SIP Interface
You need the name of the session constraints configuration to apply the restrictions you set up to a SIP interface.
To apply session and rate constraints to a SIP interface:
    ORACLE(configure)#
  3. Type sip-interface and press Enter.
    ORACLE(session-router)# sip-interface
    ORACLE(sip-interface)#
    If you are adding this feature to an existing configuration, then you will need to select the configuration you want to edit.
  4. constraint-name—Enter the name of the session constraint configuration where you have set up rate constraints to apply them to this SIP interface. This parameter has no default, and must be the valid name of a session constraint configuration.
Configuring Rate Constraints for Session Agents
You can also use this feature for individual SIP session agents.
To configure rate constraints for a SIP session agent:
    ORACLE(configure)#
  3. Type session-agent and press Enter.
    ORACLE(session-router)# session-agent
    ORACLE(session-agent)#
    ORACLE(session-agent)# rate-constraints
  5. method—Enter the SIP method name for the method you want to throttle. Your entries should come only from the following list:
    • NOTIFY
    • OPTIONS
    • MESSAGE
    • PUBLISH
    • REGISTER
  10. Save and activate your configuration.
