session-recording-server
The session-recording-server element allows you to configure SIPREC functionality.
Parameters
- name
- Name of this session recording server element.
- description
- Brief description of this session recording server. This parameter is optional.
- realm
- Realm in which this session recording server is located.
- mode
- Operating mode of this session recording server.
- selective—Unique recording server created per communication session
- persistent
- Unused
- destination
- Address of the session recording server that defines the SIP address (request URI) of the session recording server. Enter values in the format IP address or FQDN. Default is no value specified.
- port
- The port portion of the destination address.
- Default: 5060
- Min: 1025 / Max: 65535
- transport-method
- Protocol used to communicate with the recording server.
- Default: DynamicTCP
- UDP
- UDP+TCP
- DynamicTCP
- StaticTCP
- DynamicTLS
- StaticTLS
- DTLS
- TLS+DTLS
- StaticSCTP
- ping-method
- SIP method type to ping with session recording server.
- ping-interval
- Rate at which to ping the Session Agent configured as a session recording server.
- Default: 0
- Min: 0 / Max: 4294967295
- refresh-interval
Enables the SIP OPTIONS request/response mechanism, and assign a value to the refresh-timer toward the SIPREC server. This measures the maximum allowed interval (in seconds) between the OPTIONS request sent by the call-recording client and the OPTIONS response returned by the call-recording server.
By default, refresh-interval is set to 0, which disables detection of a failed recording session dialog. Assignment of any non-zero value enables detection and sets the allowable interval between OPTIONS requests and responses.- Default: 0
Path
session-recording-server is an element under the session-router path. The full path from the topmost ACLI prompt is:
