clear-deny
The clear-deny command deletes a denied ACL entry.
Syntax
clear-deny [<index> | “all”]
Arguments
- <index> Enter the index number of the ACL entry to delete
- <“all”> Delete all denied ACL entries
Mode
Superuser
Example
ORACLE# clear-deny all
Use the acl-show command to identify the index of a specific ACL entry. Use the clear-deny all command to delete all of the deny entries. This command replaces the acl-delete command from previous versions.
