test-pattern-rule
The test-pattern-rule command allows you to test header manipulation pattern rules for expression validation.
Arguments
<expression> Enter the regular expression that you want to test. The Oracle Communications Session Border Controller informs you whether or not there is a match.<string> Enter the string against which you want to compare the regular expression<show> View the test pattern you entered, whether there was a match, and if so, the number of matches<exit> End the test UserMode
User
Example
ORACLE# test-pattern-rule expression ‘.*;tgid=(.+).*’
This command exists both as a command and as a configuration element.
