prompt-enabled
The Oracle Communications Session Border Controller lets you know if a configuration has been changed and you’ve applied the done command, but have not saved and activated yet. When you issue the done command and return to Superuser mode, the ACLI prompt prefixes two asterisks (**). When you have saved, but not yet activated, the ACLI prompt prefixes one asterisk (*).
The prompt-enabled command allows you to decide whether or not you want the Oracle Communications Session Border Controller to give you this prompt. When this command is entered without an argument, the Oracle Communications Session Border Controller displays the current setting of the prompt.
Syntax
prompt-enabled <enabled | disabled>
Arguments
enabled - Enable the prompt-enabled feature
disabled - Disable the prompt-enabled feature
Mode
Superuser
Example
ORACLE# prompt-enabled disabled
