auth-params
The auth-params element provides a list of RADIUS servers used for authentication, along with protocol and operation details that define RADIUS access.
Parameters
- name
- Enter the name of this instance of the auth-params configuration element.
- protocol
- Enter the protocol to use for obtaining authentication data from a RADIUS server.
- Default: eap
- Values: eap
The current software version only supports EAP. - strategy
- Enter the management strategy used to distribute authentication requests. This parameter is only relevant if multiple RADIUS servers have been identified by the servers parameter.
- Default: hunt
- Values: round-robin | hunt
- server
- Enter a RADIUS server by IP address.
Path
auth-params is an element under the security path. The full path from the topmost ACLI prompt is: .
