security-config
The security-config configuration element allows you to configure global TLS parameters.
Parameters
- ocsr-monitoring-traps
- Enable ocsr monitoring traps
- Default: enabled
- Values: enabled | disabled
- srtp-msm-password
- The shared secret used to derive the key for encrypting SDES keying material that is placed in the media attribute of an SDP media description.
- srtp-msm-attr-name
- Specifies the name of the media attribute used to convey SDES keying information within a SDP media description.
- Default: X-acme-srtp-msm
- image-integrity-value
- Sets the known SHA-256 HMAC value that is computed for the boot image.
- local-cert-exp-trap-int
- The local certificate expiration trap interval.
- Default: 0 (disabled)
- local-cert-exp-warn-period
- The local certificate expiration warning period.
Path: security-config is an element of the security path. The full path from the topmost ACLI prompt is: .
