tcp-media-profile > tcp-media-profile-entry
The tcp-media-profile-entry configuration element allows you to enter individual tcp media profile entry elements. These are used for MSRP functionality.
Parameters
- media-type
- A string used to match with the media type <media> in the SDP message's media description (m=). For example: "message" for MSRP.
- Default: message
- transport-protocol
- The string used to match with the transport protocol <proto> in the media description (m=). For example: "TCP/TLS" for MSRP over TCP/TLS.
- listen-port
- The listening port on which the system listens for incoming connections to establish a TCP connection for a media session. If the value of this field is 0, the listening port will be chosen automatically by the system from the steering pool of the realm (which the tcp-media-profile belongs to).
- Default: 0
- Values: 0-65535
- prefered-setup-role
- The value used by the system for the a=setup attribute when negotiating the setup role, regardless of whether the
Oracle Communications Session Border Controller is an offer or answer in the SDP offer/answer exchange.
- Default: passive
- Values: active | passive
- tls-profile
- Identify the TLS profile that specifies the cryptographic resources availible to support TLS operations. This is configured when transport protocol is set to TCP/TLS/MSRP. This parameter can be safely ignored if transport-protocol is TCP/MSRP.
- require-fingerprint
- If transport-protocol is TCP/TLS/MASP, use the require-fingerprint parameter to enable or disable endpoint authentication using the certificate fingerprint methodology defined in RFC 4572. This parameter can be ignored if transport-protocol is TCP/MSRP.
- Default: disabled
- Values: enabled | disabled
Path
tcp-media-profile-entry is a subelement of tcp-media-profile. The full path from the topmost ACLI prompt is:.
