tcb
The tcb command displays task control block (TCB) information for a particular task.
Syntax
tcb <task>
This command returns a pointer to the TCB for a specified task. Although all task state information is contained in the TCB, you must not modify it directly. This command is used only for debugging purposes.Arguments
<task> — Enter a task name or task IDMode
Superuser
Example
ORACLE# tcb sipd
