clear-alarm
The clear-alarm command clears a specified alarm.
Syntax
clear-alarm <alarm_id> <task_id>
Arguments
<alarm_id> Enter a unique 32-bit integer that contains a 16-bit category name or number and a unique 16-bit identifier for the error or failure within that category
<task_id> Enter the task ID of the task that sent the alarm
Example
ORACLE# clear-alarm 65524 sip
For alarm identification and task codes for specific alarms, use the display-alarms command.
