allowed-elements-profile > rule-sets
This configuration subelement is used to configure SIP whitelists which controls the passage of unknown headers and parameters in request and response traffic.
Parameters
- name
- A unique identifier of this rule set.
- unmatched-action
- Identifies the action that the
Oracle Communications Session Border Controller performs when it encounters a non-whitelisted header.
- Default: Reject
- Values: reject | delete
- msg-type
- Specifies the message type to which the rule applies
- Default: any
- Values: any | request | response
- methods
- Specifies list of methods to which the rule applies. This applies to all methods when none are specified. Enter this as a comma separated list.
- logging
- Enables logging when an unmatched element is intercepted.
- Default: disabled
Path
rule-sets is a subelement under the allowed-elements-profile element under the session router path. The full path from the topmost ACLI prompt is: .
