session-agent-id-rule
The session-agent-id-rule specifies the SIP header of the ingress SIP message that can be used in identifying the session-agents. The rule consists of four parameters: name, match-header, match-parameter and uri-type. All the parameters must follow the Name Format.
Parameters
Path
session-agent-id-rule is an element under the session-router-config path. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
