PreviousNextJavaScript must be enabled to correctly display this content
spl-config > plugins
Parameters
name
Enter the SPL package to load. The default location is /code/spl. You may enter a single SPL plugin within a package as follows: SPL_PACKAGE:MODIFY-HEADER
move
Move plugin
Path
spl-config
is an element under the system path. The full path from the topmost ACLI prompt is:
configure terminal
> system
> spl-config
> plugins.
