sip-manipulation > mime-isup-rules > mime-header-rules
The mime-header-rules subelement of mime-isup-rules allows you to configure a SIP header manipulation to add an ISUP body to a SIP message.
Parameters
- name
- Enter a unique identifier for this MIME header rule.
- mime-header-name
- Enter the value used for comparison with the specific header in the body part of the SIP message. There is no default for this parameter.
- action
- Choose the type of action you want to be performed.
- Default: none
- Values: add | replace | store | sip-manip | find-replace-all | none
- comparison-type
- Select a method to determine how the header in the body part of the SIP message is compared. This choice dictates how the
Oracle Communications Session Border Controller processes the match rules against the SIP header.
- Default: case-sensitive
- Values: case-sensitive | case-insensitive | pattern-rule | refer-case-sensitive | refer-case-insensitive | boolean
- match-value
- Enter the value to match against the header in the body part of the SIP message. This is where you can enter values to match using regular expression values. Your entries can contain Boolean operators.
- new-value
Path
mime-headersis a subelement under the sip-manipulation>mime-isup-rules element. The full path from the topmost ACLI prompt is: configure terminal > session-router > sip-manipulation > mime-isup-rules > mime-headers.
This is a multiple instance configuration element.
