ssh-pub-key
The ssh-pub-key command allows you to display, import, and delete public key records on the Oracle Communications Session Border Controller.
Syntax
ssh-pub-key [delete | export | generate | import] <login name>
Arguments
delete <key name> — Delete an SSH public key associated with a specific name.
export <key name>— Displays a public key in RFC 4716 (SECSH) format, by object name, on the screen.
generate <key name> — Generate an SSH key pair for an existing key.
import — Import an SSH public key.
- authorized-key <key name> — Import a key you will paste into the ACLI with the supplied object name.
- known-host <key name> — Import a host key you will paste into the ACLI with the supplied object name.
Mode
Superuser
Example
ORACLE# ssh-pub-key import authorized-key jdoe
