static-flow
The static-flow element sets preconfigured flows that allow a specific class of traffic to pass through the Oracle Communications Session Border Controller unrestricted.
Parameters
- in-realm-id
- Enter the ingress realm or interface source of packets to match for static flow translation. This in-realm-id field value must correspond to a valid identifier field entry in a realm-config. This is a required field. Entries in this field must follow the Name Format.
- description
- Provide a brief description of this static-flow configuration object.
- in-source
- Enter the incoming source IP address and port of packets to match for static flow translation. IP address of 0.0.0.0 matches any source address. Port 0 matches packets received on any port. The port value has no impact on system operation if either ICMP or ALL is the selected protocol. The in-source parameter takes the format:
in-source <ip-address>[:<port>] - in-destination
- Enter the incoming destination IP address and port of packets to match for static-flow translation. An IP address of 0.0.0.0 matches any source address. Port 0 matches packets received on any port. The port value has no impact on system operation if either ICMP or ALL is the selected protocol. The in-destination parameter takes the format:
in-destination <ip-address>[:<port>]- Default: 0.0.0.0
- Values: Port: Min: 0 / Max: 65535
This parameter accepts an IPv6 value.
- out-realm-id
- Enter the egress realm or interface source of packets to match for static flow translation. This out-realm-id field value must be a valid identifier for a configured realm. This required entry must follow the Name Format.
- out-source
- Enter the outgoing source IP address and port of packets to translate to for static flow translation. IP address of 0.0.0.0 translates to any source address. Port 0 translates to packets sent on any port. The port value has no impact on system operation if either ICMP or ALL is the selected protocol. The out-source parameter takes the format:
out-source <ip-address>[:<port>]- Default: 0.0.0.0
- out-destination
- Enter the outgoing destination IP address and port of packets to translate to for static-flow translation. An IP address of 0.0.0.0 matches any source address. Port 0 translates to packets sent on any port. The port value has no impact on system operation if either ICMP or ALL is the selected protocol. The out-destination parameter takes the format:
out-destination <ip-address>[:<port>]- Default: 0.0.0.0
- protocol
- Select the protocol for this static-flow. The protocol selected must match the protocol in the IP header. The protocol remains the same for the inbound and outbound sides of the packet flow.
- Default: UDP
- Values:
- UDP—UDP used for this static-flow element
- TCP—TCP used for this static-flow element
- ICMP—ICMP used for this static-flow element
- ALL—Static-flow element can accept flows via any of the available protocols.
- alg-type
- Select the type of NAT ALG to use
- Default: none
- Values:
- none—No dynamic ALG functionality
- NAPT—Configure as NAPT ALG
- TFTP—Configure as TFTP ALG
- average-rate-limit
- Enter the maximum speed in bytes per second for this static flow
- Default 0
- Values: Min: 0 / Max: 125000000
- start-port
- Enter the internal starting ALG ephemeral port
- Default: 0
- Values: Min: 1025 / Max: 65535
- end-port
- Enter the internal ending ALG ephemeral port
- Default: 0
- flow-time-limit
- Enter the time limit for a flow, measured in seconds
- Values: Min: 0 / Max: 999999999
- initial-guard-timer
- Enter the initial flow guard timer, measured in seconds
- subsq-guard-timer
- Enter the subsequent flow guard timer, measured in seconds
Path
static-flow is an element under the media-manager path. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
