media-sec-policy
The media-sec-policy configuration element lets you access configuration elements concerning media security configuration.
Parameters
- name
- Name of this media-sec-policy object.
- pass-through
- Enable or disable pass-through mode. When enabled, the User Agent (UA) endpoints negotiate security parameters between each other; consequently, the
Oracle Communications Session Border Controller simply passes SRTP traffic between the two endpoints.
With pass-thru mode disabled (the default state), the Oracle Communications Session Border Controller disallows end-to-end negotiation — rather the Oracle Communications Session Border Controller initiates and terminates SRTP tunnels with both endpoints.
- Default: disabled
- Values: enabled | disabled
- options
- Options configured on this media security policy
- outbound
- Enter this subelement to configure the policy parameters when this policy applies to outbound traffic.
- inbound
- Enter this subelement to configure the policy parameters when this policy applies to inbound traffic.
Path
media-sec-policy is a configuration element under the security > media-security path. The full path from the topmost ACLI prompt is: .
