ipsec > security-association > tunnel-mode
This configuration element allows you to configure the addresses in the security-association. These addresses represent the external, public addresses of the termination points for the IPSEC tunnel.
Parameters
Path
tunnel-mode is a subelement under the ipsec>security-association The full path from the topmost ACLI prompt is: configure-terminal > security > ipsec > security-association>tunnel-mode. configure-terminal > security > ipsec > security-association>tunnel-mode.
