check-space-remaining
The check-space-remaining command displays the remaining amount of space in the boot directory, code (or flash memory), and ramdrv devices.
Syntax
check-space-remaining <device>
Argument
<device> Select where to check the remaining spaceValues:
- boot
- code
- ramdrv
Mode
Superuser
Example
ORACLE# check-space-remaining boot
The output of this command is in bytes.
