realm-group
The realm-group configuration element allows you to configure realm groups. Realm groups are sets of source and destination realms that allow early media to flow in the direction you configure.
Parameters
- name
- Enter the name of this realm group
- source-realm
- Enter the list of one or more global/SIP realms that you want to designate as source realms for the purpose of blocking early media; this is the realm identifier value for the realms you want on the list. To enter more than one realm in this list, list all items separated by a comma and enclose the entire entry in quotation marks.
- destination-realm
- Enter the list of one or more global/SIP realms that you want to designate as destination realms for the purpose of blocking early media; this is the realm identifier value for the realms you want on the list. To enter more than one realm in the list, list all items separated by a comma and enclose the entire entry in quotation marks
- early-media-allow-direction
- Set the direction for which early media is allowed for this realm group.
- Default: both
- Values:
- none—Turns off the feature for this realm group by blocking early media
- reverse - Allows early media to flow from called to caller.
- both - Allows early media to flow to/from called and caller
- state
- Enable or disable this realm group
- Default: disabled
- Values: enabled | disabled
Path
realm-group is an element of the media-manager path. The full path from the topmost ACLI prompt is: configure terminal > media-manager > realm-group.
