tscf-interface
Used to configure interfaces for the TSCF application.
Parameters
- state
- Operational state of this TSCF interface.
- Default: enabled
- Values: enabled | disabled
- realm-id
- Realm in which this TSCF interface exists.
- max-tunnels
- Maximum number of tunnels this TSCF interface supports.
- Default: 0
- Values: 0 - 200000
- local-address-pools
- Local address pool that provides tunnel addresses to TSCF clients. This value should be an existing tscf-address-pool configuration element name.
- nagle-state
- The operational mode of the Nagle algorithm on this TSCF interface.
- Default: enabled
- assigned-services
- This parameter is used to enable one of more services supported by this TSCF interface.
- Values: SIP | redundancy | DDT | server-keepalive | nagle | STG | inter-client-block
- tscf-ports
- This is used to access the tscf-port subelement.
Path
tscf-interface is an element within the path. The full path from the topmost ACLI prompt is
