display-current-cfg-version
The display-current-cfg-version command displays the current configuration version.
Syntax
Arguments
none
Mode
User
Example
ORACLE# display-current-cfg-version
This command displays the saved version number of the current configuration. This integer value is incremented by one for each new configuration version.
