sip-feature-caps
Configure to support SRVCC handover and other ATCF functionality.
Parameters
- state
- When enabled, the feature adds the Feature-Caps header to
messages.
- Default: disabled
- Values: enabled | disabled
- atcf-management-uri
- Identifies the feature capability indicator that will be used to
transport the ATCF management URI. When the value is
management and the
value of
state is
enabled, the
Feature-Caps header "g.3gpp atcf-mgmt-uri" is added and the value of atcf-psi-dn in
the
sip-config configuration element. When the value is
psi and the value of
state is
enabled, the
Feature-Caps header "g.3gpp atcf-psi" is added and the value is the value
of
atcf-psi-dn in the
sip-config
- Default: management
- Values: management | psi
- atcf-alerting
- When enabled, the system adds the Feature-Caps header to messages
and turns on the alerting feature.
- Default: disabled
- atcf-pre-alerting
and turns on the pre-alerting feature.
- Default: disabled
Path
sip-feature-caps is an element within the path.
