capture-receiver
The capture-receiver configuration element allows you to specify a target for packet mirroring from the Oracle Communications Session Border Controller to that target. This command is only applicable to packet-trace remote.
Parameters
- state
- Enable or disable the
Oracle Communications Session Border Controller’s TRACE capability.
- Default: disabled
- Values: enabled | disabled
- address
- Enter the TRACE server IP address.
- network-interface
- Enter the TRACE server outbound interface. The argument accepts the full interface name, including the sub-port-id. The command assumes sub-port-id 0 if it is not specified.
Path
capture-receiverIs an element of the system path. The full path from the topmost ACLI prompt is: configure terminal > system > capture-receiver.
