phy-interface
The phy-interface element is used to configure physical interfaces.
Parameters
- name
- Enter the name for this physical interface. Physical interfaces with an operation-type of Control or Maintenance must begin with “wancom.” This is a required field. Entries in this field must follow the Name Format. Name values for the phy-interface must be unique.
- operation-type
- Select the type of physical interface connection
- Default: Control
- Values:
- Media—Front-panel interfaces only. Port: 0-3 Slot: 0 or 1
- Control—Rear-panel interfaces only. Port 0, 1, or 2 Slot: 0
- Maintenance —Rear-panel interfaces only. Port 0, 1, or 2 Slot: 0
- port
- Select the physical port number on an interface of the phy-interface being configured
- Default: 0
- Values:
- 0-2 for rear-panel interfaces
- 0-1 for two possible GigE ports on front of Oracle Communications Session Border Controller chassis
- 0-3 for four possible FastE ports on front of Oracle Communications Session Border Controller chassis
- slot
- Select the physical slot number on the
- Default: 0
- Values:
- 0 is the motherboard (rear-panel interface) if the name begins with “wancom”
- 0 is the left Phy media slot on front of Oracle Communications Session Border Controller chassis
- 1 is the right Phy media slot on front of Oracle Communications Session Border Controller chassis
- virtual-mac
- Enter the MAC address identifying a front-panel interface when the Oracle Communications Session Border Controller is in the Active state. This field value should be generated from the unused MAC addresses assigned to a Oracle Communications Session Border Controller. The virtual-mac field is only applicable for front interfaces.
- admin-state
- Enable or disable the
Oracle Communications Session Border Controller to allow incoming and outgoing traffic to be processed using the front physical interface cards
- Default: enabled
- Values: enabled | disabled
- auto-negotiation
- Enable or disable auto negotiation on front Phy card interfaces taking place before either end begins sending packets over the Ethernet link. The auto-negotiation field is only applicable for front interfaces. The value configured in this field does not change the
Oracle Communications Session Border Controller status at runtime.
- Default: enabled
- duplex-mode
- Set whether the 10/100 Phy card interfaces located on the front panel of
Oracle Communications Session Border Controller operate in full-duplex mode or half-duplex mode
- Default: full
- Values: full | half
- speed
- Set the speed in Mbps of the front-panel 10/100 Phy interfaces; this field is only used if the auto-negotiation field is set to disabled for 10/100 Phy cards
- Default: 100
- Values: 10 | 100
- wancom-health-score
- Enter the amount to subtract from the
Oracle Communications Session Border Controller’s health score if a rear interface link goes down
- Default: 50
- Values: Min: 0 | Max: 100
- network-alarm-threshold
- Access the network-alarm-threshold subelement.
- overload-protection
- Enable this parameter to turn graceful call control on. Disable (default) if you do not want to use this feature.
- Default: disabled
- Default: disabled
Path
phy-interface is an element under the system path. The full path from the topmost ACLI prompt is: .
Certain fields are visible based on the setting of the operation-type parameter. This is a multiple instance configuration subelement.
