PreviousNextJavaScript must be enabled to correctly display this content
local-response-map
The local-response-map configuration element is used for RFC3326 support.
Parameters
entries
Enter the entries configuration subelement.
delete
Remove the specified response map entry type.
edit
Select a pre- configured RFC 3326 response map for media not allocated
Path
local-response-map is an element under the session router path. The full path from the topmost ACLI prompt is:
configure terminal
> session-router
> local-response-map.
