monitor
The monitor command displays real-time media or signaling statistics.
Syntax
monitor <media | session>
Arguments
- <media> - Enter the media you want to monitor
- <session> - Enter the session you want to monitor
Mode
User
Example
This command outputs real-time media and signaling statistics to the ACLI. Pressing a numerical digit (0-9) changes the refresh rate to that interval in seconds. By default, there is a 2 second refresh rate. Type "q" to exit the monitor display. Monitor session will display the equivalent of show sipd statistics, and monitor media will display the equivalent of show mbcd statistics.ORACLE# monitor media
