cert-status-profile
The cert-status-profile configuration element identifies an OCSP responder, the transport protocol used to access the responder, and the certificates used to sign the OCSP request and to validate the OCSP response.
Parameters
- name
- Enter the name of this cert-status-profile instance, thus allowing the configuration of multiple configuration elements of this type. This parameter is required.
- Default: None
- Values: Any valid object name — the name must be unique within the cert-status-profile namespace
- ip-address
- Enter the IPv4 address of the destination OCSP responder. This parameter is required.
- Default: None
- Values: Any valid IPv4 address
- hostname
- hostname of the OCSR. If this parameter and the ip-address parameter are both configured, the Oracle Communications Session Border Controller uses the IP address.
- port
- Enter the destination port number. This parameter is optional.
- Default: 80
- Values: Any valid port number
- type
- Enter the protocol type used for certificate checking. This parameter is optional.
- Default: ocsp
- Values: ocsp
The current software version only supports ocsp.
- trans-protocol
- Enter the protocol used to transmit the OSCP request; the single currently supported value is http. This parameter is optional.
- Default: http
- Values: http
- requester-cert
- Enter the name of the certificate configuration element used to sign the outgoing OCSP request; this parameter is required only if the OCSP responder mandates a signed request.
- Default: None
- Values: An existing certificate configuration element name
- responder-cert
- Enter the name of the certificate configuration element used to validate the incoming OCSP response.
- Default: None
- realm-id
- Enter the name of the realm used for transmitting OCSP requests. This parameter is optional.
- Default: wancom
- Values Any valid realm name
- retry-count
- Enter the maximum number of times to retry an OCSP responder in the event of connection failure.
- Default: 1
- Values: Min: 0/Max: 10
- dead-time
- Enter the interval (in seconds) between the trigger of the retry-count(er) and the next attempt to access the unavailable OCSP responder. This parameter is optional.
- Default: 0 (seconds)
- Values: Min: 0/Max: 3600
Path
cert-status-profile is a subelement under the security configuration element. The full path from the topmost ACLI prompt is: .
This is a multiple instance configuration.
