msrp-config
The msrp-config element is used to configure global MSRP functionality.
Parameters
- state
- Enables MSRP operations.
- Default: enabled
- enabled | disabled
- uri-translation
Enables or disables NAT of URIs found in the From-Path and To- Path headers of MSRP requests and responses, and in a=path attributes found in SDP offers.
- Default: enabled
- session-inactivity-timer
This parameter is configured in connection with the sipconfig > msrp-delayed-bye-timer parameter to implement the delayed transmission of SIP BYE requests. The session-inactivity-timer parameter specifies the maximum inactivity interval (defined as the absence of transmitted data) tolerated before the MSRP connection is terminated.
- Default: 5
- Min: 5 / Max: 10
Path
msrp-config is an element of the media-manager path. The full path from the topmost ACLI prompt is: .
