Show Commands Associated with HDR Groups
This section provides ACLI show command output tables and descriptions. These show commands are associated with the HDR Groups described in the section, ACLI-Associated Groups and Group Statistics.
The show sipd agents command is associated with the session-agent HDR Group, and the show sipd realms command is associated with the session-realm HDR Group (in the section MIB-Associated Groups and Group Statistics). The show sipd realm command is also associated with the registration-realm HDR Group in the section, ACLI-Associated Groups and Group Statistics.show sipd sessions
The show sipd sessions command displays information about SIP session transactions on the OCSBC. These statistics include session information over Period and Lifetime monitoring spans, as well as information on active sessions. For associated HDR Group and Group Statistics, see sip-sessions.
ORACLE> show sipd sessions
09:40:09-105
SIP Session Status         -- Period -- -------- Lifetime --------
                 Active    High   Total      Total  PerMax    High
Sessions             10      10      10         65      10      55
  Initial            10      30      40         65      50       5
  Early              20      10      30         65      45      10
  Established        15      10      25         60      30      35
  Terminated          3       0       3          5      10      10
Dialogs              10       3      13         45      20      30
  Early               7       8      15         47      25      25
  Confirmed          15       0      15         60      40      10
  Terminated          4       0       4         45      25      20
| Parameter | Description |
| Sessions | Number of sessions established by INVITE and SUBSCRIBE messages |
| Initial | Number of sessions for which an INVITE or SUBSCRIBE is being forwarded. |
| Early | Number of sessions for which the first provisional response (1xx other than 100) is received. |
| Established | Number of sessions for which a success (2xx) response is received. |
| Terminated | Number of sessions for which the session is ended by receiving or sending a BYE for an “Established” session or forwarding an error response for an “Initial” or “Early” session. The session remains in the Terminated state until all the resources for the session are freed. |
| Dialogs | Number of end-to-end SIP signaling connections. |
| Early | Number of dialogs created by a provisional response. |
| Confirmed | Number of dialogs created by a success response. An “Early” dialog transitions to Confirmed when a success response is received. |
| Terminated | Number of dialogs that ended by receiving/sending a BYE for an “Established” session or receiving/sending error response “Early” dialog. The dialog remains in the Terminated state until all the resources for the session are freed. |
show sipd agents
The show sipd agents command displays statistics related to defined SIP session agents. SIP session agents can be softswitches, SIP proxies, application servers, SIP gateways, or SIP endpoints.
In addition to functioning as a single logical next hop for a signaling message (for example, where a SIP INVITE is forwarded), session agents can provide information about next or previous hops for packets in a SIP agent, including providing a list of equivalent next hops.
Entering this show command without arguments, list all SIP session agents. By adding the IP address or hostname of a session agent as well as a specified method at the end of the command, you can display statistics for that specific session agent and method. For associated HDR Group and Group Statistics, see session-agent.
When the FQDN-resolved Session Agent Statistics are enabled with the sa-routes-stats parameter set to enabled, the format session-agent-hostname#IP-address is used to indicate each IP address returned for a DNS query on a session agent configured as a hostname.
Show sipd agents Command
ORACLE> show sipd agents
11:44:S1-49 (recent)
                ------Inbound------ ---- Outbound ---- -- Latency --   Max
Session Agent   Active  Rate  Confix Active  Rate Confix   Avg   Max   Burst
session—agent1  I    0   0.0      0      0   0.0     0 0.000 0.000       0
session—agent2  I    0   0.0      0      0   0.0     0 0.000 0.000       0
| Session Agent | Host name of the session agent in Fully Qualified Domain Name (FQDN) or IP Address format (softswitch, SIP proxy, application server, SIP gateway or SIP endpoint). |
| Inbound | |
| Active | Total number of current, active inbound sessions sent to the session agent. |
| Rate | Average rate of inbound session invitations (per second) sent to the session agent. |
| ConEx | Number of times that signaling & bandwidth constraints for inbound packets sent to the session agent were exceeded on the session agent. This helps determine resource availability. |
| Outbound | |
| Active | Total number of current, active outbound sessions sent to the session agent. |
| Rate | Average rate of outbound session invitations (per second) sent to the session agent. |
| ConEx | Number of times that signaling & bandwidth constraints for outbound packets were exceeded on the session agent. This helps determine resource availability. |
| Latency | |
| Avg | Average amount of time between the moment the session-agent transmits a SIP packet and the moment it reaches its destination. |
| Max | Maximum amount of time between the moment the session-agent transmits a SIP packet and the moment it reaches its destination. |
| Max Burst | Maximum burst rate for each session agent as total number of session invitations sent to or received from the session agent within the amount of time configured for the burst-rate window. |
Show sipd agents <IP address or hostname> Command
AcmePacket> show sipd agents session—agent1
12:11:17-51
Session Agent session-agent1(public) [In Service]
                         ------ Period -----  ----- Lifetime -----
Inbound Sessions              0     0      0       0       0     0
Rate Exceeded                 -     -      0       0       0     -
Num Exceeded                  -     -      0       0       0     -
Burst Rate                    0     0      0       0       0     0
Reg Rate Exceeded             -     -      0       0       0     -
Outbound Sessions             0     1      11      11      11    1
Rate Exceeded                 -     0      0       0       0     -
Burst Rate                    0     11     0       0       0     11
Out of Service                -     -      0       0       0     -
Trans Timeout                 0     0      0       0       0     0
Requests Sent                 -     -      0       0       0     -
Requests Complete             -     -      0       0       0     -
Seizure                       -     -      0       0       0     -
Answer                        -     -      0       0       0     -
ASR Exceeded                  -     -      0       0       0     -
Messages Received             -     -      30      30      30    -
Latency=0.000: max=0.000
| Inbound Sessions | Number of inbound SIP sessions for this session agent. |
| Rate Exceeded | Number of times session rate was exceeded for inbound SIP sessions on this session agent. |
| Num Exceeded | Number of times that signaling & bandwidth constraints for inbound SIP sessions were exceeded on this session agent. This helps determine resource availability. |
| Burst Rate | Number of times burst rate was exceeded for this session agent on inbound SIP sessions. |
| Reg Rate Exceeded | Number of times the registration rate was exceeded for this session agent on inbound SIP sessions. |
| Outbound Sessions | Number of outbound SIP sessions for this session agent. |
| Rate Exceeded | Number of times session rate was exceeded for outbound SIP sessions. |
| Num Exceeded | Number of times time constraints were exceeded for outbound SIP sessions. |
| Burst Rate | Maximum burst rate of traffic (both inbound and outbound). |
| Reg Rate Exceeded | Number of times the registration rate was exceeded for this session agent on outbound SIP sessions. |
| Out of Service | Number of times this session agent went out of service. |
| Trans Timeout | Number of SIP transactions that timed out for this session agent. |
| Requests Sent | Number of SIP requests sent via this session agent. |
| Requests Complete | Number of SIP requests completed for this session agent. |
| Seizure | Number of seizures that occurred on this session agent. |
| Answer | Number of answered SIP sessions on this session agent. |
| ASR Exceeded | Number of times that Access Service Requests (ASRs) were exceeded on this session agent. |
| Messages Received | Number of SIP messages received by this session agent. |
| Latency | Average and maximum amount of time between the moment the session-agent transmits a SIP packet and the moment it reaches its destination. |
show sipd acls
An access control list (ACL) allows/denies specific sources (IP or IP:port) to access the OCSBC.
The show sipd acls command displays information about SIP ACL activity on the OCSBC. These statistics include ACL information over Period and Lifetime monitoring spans, as well as information on active ACL status. For associated HDR Group and Group Statistics, see sip-acl-oper and sip-acl-status.
ORACLE> show sipd acls
09:12:04-120
SIP ACL Status             -- Period -- -------- Lifetime --------
Total Entries         0       0       0          0       0       0
Trusted               0       0       0          0       0       0
Blocked               0       0       0          0       0       0
Blocked NATs          0       0       0          0       0       0
ACL Operations                  ---- Lifetime ----
                         Recent      Total  PerMax
ACL Requests                  0          0       0
Bad Messages                  0          0       0
Promotions                    0          0       0
Demotions                     0          0       0
Trust->Untrust                0          0       0
Untrust->Deny                 0          0       0
| SIP ACL Status | |
| Total Entries | Total number of ACL entries, both trusted and blocked. |
| Trusted | Number of trusted ACL entries |
| Blocked | Number of blocked ACL entries |
| ACL Operations | |
| ACL Requests | Number of ACL requests |
| Bad Messages | Number of bad messages |
| Promotions | Total number of ACL entry promotions. These are the ACL entries that have been promoted from untrusted to trusted status. |
| Demotions | Number of ACL entry demotions. |
| Trust->Untrust | Number of ACL entries demoted from trusted to untrusted |
| Untrust->Deny | Number of ACL entries demoted from untrusted to deny |
show sipd client
A SIP client can initiate and terminate SIP sessions. The show sipd client command displays statistics for SIP client events when the OCSBC is acting as a SIP client in its back-to-back User Agent (B2BUA) role. These statistics include SIP client information over Period and Lifetime monitoring spans, as well as information on active SIP client status. For associated HDR Group and Group Statistics, see sip-client.
ORACLE> show sipd client
09:28:15-191
SIP Client Trans           -- Period -- -------- Lifetime --------
All States            0       0       0          0       0       0
<Initial>             0       0       0          0       0       0
<Trying>              0       0       0          0       0       0
<Calling>             0       0       0          0       0       0
<Proceeding>          0       0       0          0       0       0
<Cancelled>           0       0       0          0       0       0
<EarlyMedia>          0       0       0          0       0       0
<Completed>           0       0       0          0       0       0
<SetMedia>            0       0       0          0       0       0
<Established>         0       0       0          0       0       0
<Terminated>          0       0       0          0       0       0
| All States | Number of all client session transactions |
| Initial | Number of times the Initial state was entered due to the receipt of a request |
| Trying | Number of times the Trying state was entered due to the receipt of a request |
| Calling | Number of times the Calling state was entered due to the receipt of an INVITE request |
| Proceeding | Number of times the “Proceeding” state was entered due to the receipt of a provisional response while in the Calling state |
| Cancelled | Number of INVITE transactions that received a CANCEL |
| EarlyMedia | Number of times the “Proceeding” state was entered due to the receipt of a provisional response that contained a Session Description Protocol (SDP) while in the Calling state |
| Completed | Number of times that the “Completed” state was entered due to the receipt of a status code in the range of 300-699 when either in the “Calling” or Proceeding state |
| SetMedia | Number of transactions in which the OCSBC was setting up NAT and steering ports |
| Established | Number of times the client received a 2xx response to an INVITE, but could not forward it because the NAT and steering port information was missing |
| Terminated | Number of times the Terminated state was entered after a 2xx message |
show sipd server
A SIP server can receive and terminate SIP sessions. The show sipd server command displays statistics for SIP server events when the OCSBC is acting as a SIP server in its back-to-back User Agent (B2BUA) role. These statistics include SIP server information over Period and Lifetime monitoring spans, as well as information on active SIP server status. For associated HDR Group and Group Statistics, see sip-server.
ORACLE> show sipd server
09:39:22-158
SIP Server Trans           -- Period -- -------- Lifetime --------
<Queued>              0       0       0          0       0       0
<Confirmed>           0       0       0          0       0       0
| All States | Number of all server session transactions |
| Queued | Number of times the Queued state was entered due to the receipt of a request |
| Established | Number of times the server received a 2xx response to an INVITE, but could not forward it because the NAT and steering port information was missing |
| Confirmed | Number of times that an ACK was received while the server was in “Completed” state, and then transitioned to the Confirmed state |
| Terminated | Number of times the Terminated state was entered after a 2xx message, or never received an ACK in the “Completed” state, and then transitioned to the Terminated state. |
show sipd policy
Multistage local policy routing enables the OCSBC to perform multiple stages of route lookups where the result from one stage is used as the lookup key for the next routing stage.
The show sipd policy command displays single and multistage local policy lookups. All counters are reported for the recent, lifetime total, and lifetime maximum periods. For associated HDR Group and Group Statistics, see sip-policy.
ORACLE> show sipd policy
09:38:43-118
SIP Policy/Routing            ---- Lifetime ----
                       Recent      Total  PerMax
Local Policy Lookups        0          0       0
Local Policy Hits           0          0       0
Local Policy Misses         0          0       0
Local Policy Drops          0          0       0
Agent Group Hits            0          0       0
Agent Group Misses          0          0       0
No Routes Found             0          0       0
Missing Dialog              0          0       0
Inb SA Constraints          0          0       0
Outb SA Constraints         0          0       0
Inb REG SA Constraint       0          0       0
Out REG SA Constraint       0          0       0
Requests Challenged         0          0       0
Challenge Found             0          0       0
Challenge Not Found         0          0       0
Challenge Dropped           0          0       0
Local Policy Inits          0          0       0
Local Policy Results        0          0       0
Local Policy Exceeded       0          0       0
Local Policy Loops          0          0       0
| Local Policy Lookups | Number of local policy lookups |
| Local Policy Hits | Number of successful local policy lookups |
| Local Policy Misses | Number of local policy lookup failures |
| Local Policy Drops | Number of local policy lookups where the next hop session agent group is H.323 |
| Agent Group Hits | Number of successful local policy lookups for session agent groups |
| Agent Group Misses | Number of successful local policy lookups where no session agent was available for the session agent group |
| No Routes Found | Number of successful local policy lookups, but temporarily unable to route (for example, session agent out of service) |
| Missing Dialog | Number of local policy lookups where the dialog was not found for a request addressed to the OCSBC with a To tag or for a NOTIFY-SUBSCRIBE SIP request |
| Inb SA Constraints | Number of successful local policy lookups where the inbound session agent (SA) exceeded constraints |
| Outb SA Constraints | Number of successful local policy lookups where the outbound SA exceeded constraints |
| Inb REG SA Constraint | Number of successful inbound local policy lookups where the registrar (REG) SA exceeded constraints |
| Outb REG SA Constraint | Number of successful outbound local policy lookups where the registrar (REG) SA exceeded constraints |
| Request Challenged | Number of requests that were challenged. |
| Challenge Found | Number of challenges found. |
| Challenge Not Found | Number of challenges not found. |
| Challenge Dropped | Number of challenges dropped. |
| Local Policy Inits | Number of times the OCSBC made an initial local policy lookup |
| Local Policy Results | Number of times the OCSBC truncated the number of routes returned for a local policy lookup because the maximum number of routes per local policy lookup (max local policy lookups routes per lookup) threshold was reached. |
| Local Policy Exceeded | Number of times the OCSBC truncated the number of routes returned for a local policy lookup because the maximum number of routes per message request (total local policy routes) threshold was reached. |
| Local Policy Loops | Number of times the OCSBC detected a loop while performing a multistage local policy lookup |
show sipd errors
The show sipd errors command displays statistics for SIP media event errors. These statistics are errors encountered by the SIP application in processing SIP media sessions, dialogs, and session descriptions (SDP). Error statistics display for the lifetime monitoring span only. For associated HDR Group and Group Statistics, see sip-errors.
ORACLE> show sipd errors
09:31:49-105
SIP Errors/Events             ---- Lifetime ----
                       Recent      Total  PerMax
SDP Offer Errors            0          0       0
SDP Answer Errors           0          0       0
Drop Media Errors           0          0       0
Transaction Errors          0          0       0
Application Errors          0          0       0
Media Exp Events            0          0       0
Early Media Exps            0          0       0
Exp Media Drops             0          0       0
Expired Sessions            0          0       0
Multiple OK Drops           0          0       0
Multiple OK Terms           0          0       0
Media Failure Drops         0          0       0
Non-ACK 2xx Drops           0          0       0
Invalid Requests            0          0       0
Invalid Responses           0          0       0
Invalid Messages            0          0       0
CAC Session Drop            0          0       0
Nsep User Exceeded          0          0       0
Nsep SA Exceeded            0          0       0
CAC BW Drop                 0          0       0
| SDP Offer Errors | Number of errors encountered in setting up the media session for a session description in a SIP request or response which is a Session Description Protocol (SDP) Offer in the Offer/Answer model (RFC 3264) |
| SDP Answer Errors | Number of errors encountered in setting up the media session for a session description in a SIP request or response which is a Session Description Protocol (SDP) Answer in the Offer/Answer model (RFC 3264) |
| Drop Media Errors | Number of errors encountered in tearing down
				  the media for a dialog or session that is being terminated due to: a) non-successful response to an INVITE transaction, or b) a BYE transaction received from one of the participants in a dialog/session, or c) a BYE initiated by the OCSBC due to a timeout notification from the Middlebox Control Daemon (MBCD). |
| Transaction Errors | Number of errors in continuing the processing of the SIP client transaction associated with setting up or tearing down of the media session. |
| Application Errors | Number of miscellaneous errors in the SIP application that are otherwise uncategorized |
| Media Exp Events | Number of flow timer expiration notifications received from the Middlebox Control Daemon (MBCD). |
| Early Media Exps | Number of flow timer expiration notifications received for media sessions that were not completely set up due to an incomplete or pending INVITE transaction |
| Exp Media Drops | Number of flow timer expiration notifications from the Middlebox Control Daemon (MBCD) that resulted in the termination of the dialog/session by the SIP application. |
| Expired Sessions | Number of sessions terminated due to the session timer expiring |
| Multiple OK Drops | Number of dialogs terminated upon reception of a 200 OK response from multiple User Agent Servers (UASs) for a given INVITE transaction that was forked by a downstream proxy |
| Multiple OK Terms | Number of dialogs terminated upon reception of a 200 OK response that conflicts with an existing established dialog on the OCSBC |
| Media Failure Drops | Number of dialogs terminated due to a failure in establishing the media session. |
| Non-Ack 2xx Drops | Number of sessions terminated because an ACK was not received for a 2xx response |
| Invalid Requests | Number of invalid requests (for example, an unsupported header was received). |
| Invalid Responses | Number of invalid responses (for example, no Via header in response) |
| Invalid Messages | Number of messages dropped due to parse failure |
| CAC Session Drop | Number of call admission control (CAC) session setup failures |
| CAC BW Drop | Number of call admission control (CAC) session setup failures due to insufficient bandwidth (BW) |
| Nsep User Exceeded | Number of Emergency Telecommunications Service (ETS), user call sessions that exceeded the calls-per-second rate configured on the OCSBC for National Security and Emergency Preparedness (NSEP). |
| Nsep SA Exceeded | Number of Emergency Telecommunications Service (ETS), Session Agent (SA) call sessions that exceeded the calls-per-second rate configured on the OCSBC for National Security and Emergency Preparedness (NSEP). |
show sipd status
The show sipd status command displays information about Session Initiation Protocol (SIP) transactions. These statistics are given for the Period and Lifetime monitoring spans. This display also provides statistics related to SIP media events. These statistics include SIP status information over Period and Lifetime monitoring spans, as well as information on active SIP status. For associated HDR Group and Group Statistics, see sip-status.
ORACLE> show sipd status
09:41:00-156
SIP Status                 -- Period -- -------- Lifetime --------
Subscriptions         0       0       0          0       0       0
Dialogs               0       0       0          0       0       0
CallID Map            0       0       0          0       0       0
Rejections            -       -       0          0       0
ReINVITEs             -       -       0          0       0
ReINV Suppress        -       -       0          0       0
Media Sessions        0       0       0          0       0       0
Media Pending         0       0       0          0       0       0
Client Trans          0       0       0          0       0       0
Server Trans          0       0       0          0       0       0
Resp Contexts         0       0       0          0       0       0
Saved Contexts        0       0       0          0       0       0
Sockets               0       0       0          0       0       0
Req Dropped           -       -       0          0       0
DNS Trans             0       0       0          0       0       0
DNS Sockets           0       0       0          0       0       0
DNS Results           0       0       0          0       0       0
Rejected Msgs         0       0       0          0       0       0
Session Rate = 0.0
Load Rate = 0.0
Remaining Connections = 200000 (max 200000)
| Subscriptions | Number of sessions established by SUBSCRIPTION |
| Dialogs | Number of end-to-end SIP signaling connections |
| CallID Map | Number of successful session header Call ID mappings |
| Rejections | Number of rejected INVITEs |
| ReINVITEs | Number of ReINVITEs |
| ReINV Suppress | Number of ReINVITEs that were suppressed |
| Media Sessions | Number of successful media sessions |
| Media Pending | Number of media sessions waiting to be established |
| Client Trans | Number of client transactions |
| Server Trans | Number of server transactions that have taken place on the OCSBC |
| Resp Contexts | Number of response contexts |
| Saved Contexts | Number of saved contexts |
| Sockets | Number of SIP sockets |
| Req Dropped | Number of dropped requests |
| DNS Trans | Number of Domain Name System (DNS) transactions |
| DNS Sockets | Number of Domain Name System (DNS) sockets |
| DNS Results | Number of Domain Name System (DNS) results |
| Rejected Msgs | Number of rejected messages |
| Session Rate | The rate, per second, of SIP invites allowed to or from the OCSBC during the sliding window period. The rate is computed every 10 seconds . |
| Load Rate | Average Central Processing Unit (CPU) utilization of the OCSBC during the current window. The average is computed every 10 seconds unless the load-limit is configured in the SIPConfig record, in which case it is 5 seconds. |
| Remaining Connections | Number of SIP connections currently available |
show sipd invite
The show sipd invite command displays information about Session Initiation Protocol (SIP) INVITE requests. These statistics are given for both Server and Client and display recent, per maximum, and total for each. For associated HDR Group and Group Statistics, see sip-invites.
ORACLE> show sipd invite
09:05:20-106
INVTTE (20:O2:28-127)
                     ------ Server -------  ------ Client -------
Message/Event        Recent  Total  PerMax  Recent  Total  PerMax
INVITE Requests           0     0        0       0      0       0
Retransmissions           0     0        0       0      0       0
Response Retrans          0     0        0       0      0       0
Transaction Timeouts      -     -        -       0      0       0
Locally Throttled         -     -        -       0      0       0
Avg Latency=0.000 for 0
Max Latency=0.000
| INVITE Requests | Number of INVITE requests |
| Retransmissions | Number of retransmissions of INVITEs |
| Response Retrans | Number of response retransmissions |
| Transaction Timeouts | Number of INVITE request transaction timeouts |
| Locally Throttled | Number of INVITE requests locally throttled |
| Avg Latency | Average latency of traffic flow for inbound and outbound packets |
| Max Latency | Maximum latency of traffic flow for inbound and outbound packets. |
show sipd realms
Realms are a logical distinction representing routes (or groups of routes) reachable by the OCSBC and what kinds of resources and special functions apply to those routes. Realms are used as a basis for determining ingress and egress associations to network interfaces, which can reside in different VPNs. The ingress realm is determined by the signaling interface on which traffic arrives. The egress realm is determined by the following:
- Routing policy - Where the egress realm is determined in the session agent configuration or external address of a SIP-NAT
- Realm-bridging - As applied in the SIP-NAT configuration and H.323 stack configurations
- Third-party routing/redirect (i.e., SIP redirect or H.323 LCF) 170
Realms can also be nested in order to form nested realm groups. Nested realms consist of separate realms that are arranged within a hierarchy to support network architectures that have separate backbone networks and VPNs for signaling and media.
The show sipd realms command displays information about sessions (both inbound and outbound), out of service sessions, early and successful sessions, and session registration information for realms. This information displays for Period and Lifetime monitoring spans, as well as for active sessions. For associated HDR Group and Group Statistics, see the session-realm, and registration-realm.
The following example shows the statistics for the realm name of public.ORACLE> show sipd realms public
15:23:54-47
Realm access() [In Service]
                            -- Period --  ------ Lifetime -----
  Rate Exceeded          -     -       0      0         0     0
  Num Exceeded           -     -       0      0         0     0
  Reg Rate Exceeded      0     0       0      0         0     0
  Reg Burst Rate         0     0       0      0         0     0
Outbound Sessions        0     0       0      0         0     0
Local Contacts           2     2       0      0         2     2
HNT Entries              0     0       0      0         0     0
Non—HNT Entries          2     2       0      0         2     2
Subscriptions            0    42      23    112        48    48
Out of Service           0     0       0      0         0     0
Requests Sent            -     -      46    222        96     -
Seizure                  -     -       0      0         0     -
Answer                   -     -       0      0         0     -
Requests Received        -     -      46    226        96     -
QoS Major Exceeded       -     -       0      0         0     -
QoS Critical Exceeded    -     -       0      0         0     -
| Inbound Sessions | Total number of active inbound sessions during an Active and Lifetime period. |
| Rate Exceeded | Number of times session rate was exceeded for inbound SIP sessions on this realm. |
| Num Exceeded | Number of times time constraints were exceeded for inbound sessions. |
| Burst Rate | Number of times burst rate was exceeded for this realm on inbound SIP sessions. |
| Reg Rate Exceeded | Number of times the registration rate was exceeded for this realm on inbound SIP sessions. |
| Reg Burst Rate | Number of times the registration burst rate was exceeded for this realm on inbound SIP sessions. |
| Outbound Sessions | Total number of active outbound sessions during an Active and Lifetime period. |
| Rate Exceeded | Number of times session rate was exceeded for outbound SIP sessions on this realm. |
| Num Exceeded | Number of times time constraints were exceeded for outbound sessions. |
| Burst Rate | Number of times burst rate was exceeded for this realm on outbound SIP sessions. |
| Reg Rate Exceeded | Number of times the registration rate was exceeded for this realm on outbound SIP sessions. |
| Local Contacts | Number of contact entries in the registration cache. |
| HNT Entries | Number of hosted NAT traversal (HNT) contact entries that are behind a NAT device. |
| Non-HNT Entries | Number of contact entries that are not hosted NAT traversal that are behind a NAT device. |
| Subscriptions | Specifies the following: Active Subscriptions: The current global count of active SIP subscriptions during Survivability. Subscriptions PreMax: The maximum global count of SIP subscriptions initiated during any 100 second period since the last OCSBC re-boot, and during Survivability. Subscriptions High: The maximum global count of active SIP subscriptions since the last OCSBC re-boot, and during Survivability. |
| Out of Service | Number of times this realm went out of service. |
| Trans Timeout | Number of transactions timed out for this realm. |
| Requests Sent | Number of requests sent via this realm. |
| Requests Complete | Number of requests that have been completed for this realm. |
| Seizure | Number of seizures that occurred on this realm. |
| ASR Exceeded | Number of times that Access Service Requests (ASRs) were exceeded on this realm. |
| Requests Received | Number of requests received on this realm. |
| QoS Major Exceeded | Number of times the major Rfactor threshold was exceeded during the sliding window period. The peg count provides counts of calls with different service classes that occur during intervals of frequency which reliability indicate the traffic load. R-factors are metrics in VoIP that use a formula to determine a numeric expression of voice quality. |
| QoS Critical Exceeded | Number of times the critical Rfactor threshold was exceeded during the sliding window period. Provides counts of calls with different service classes that occur during intervals of frequency which reliability indicate the traffic load. R-factors are metrics in VoIP that use a formula to determine a numeric expression of voice quality. |
| Latency | |
| Avg | Average amount of time between the moment the realm transmits a SIP packet and the moment it reaches its destination. |
| Max | Maximum amount of time between the moment the realm transmits a SIP packet and the moment it reaches its destination. |
| QoS R-Factor | |
| Avg | Average Quality of Service (QoS) factor observed during the current window period. Quality of service shapes traffic to provide different priority and level of performance to different data flows. R-factors are metrics in VoIP, that use a formula to take into account both user perceptions and the cumulative effect of equipment impairments to arrive at a numeric expression of voice quality. This statistic defines the call or transmission quality expressed as an R factor. |
| Max | Maximum Quality of Service (QoS) factor observed during the sliding window period. Quality of service shapes traffic to provide different priority and level of performance to different data flows. R-factors are metrics in VoIP that use a formula to determine a numeric expression of voice quality. This statistic defines the call or transmission quality expressed as an R factor. |
| Early Sessions | Indicates the number of early sessions for each realm. Each time the OCSBC receives an INVITE on the ingress realm or the egress realm sends an INVITE request, a counter increments if the session is established with a 200 OK response. This counter also increments in sessions when there are no 18x responses (Ringing (180), Call is Being Forwarded (181), Queued (182), Session in Progress (183)), but a 200 OK is established. This counter represents the number of sessions that have reached the early dialog state or later. |
| Successful Sessions | Indicates the number of successful sessions for
				  each realm. Successful sessions are when the
				  OCSBC receives a
				  successful 200 OK response from an initial INVITE request. Note: This counter is NOT incremented for re-INVITES. |
| Initial Registrations | |
| Total | Total number of initial registrations. This
				  counter is incremented once for each initial REGISTER message even when the
				  REGISTER is challenged. This counter is based on ingress (received) messages
				  only. Note: This counter is not incremented when registrations are challenged by the following response messages: 401 (Unauthorized - user authentication required) 407 (Proxy authentication required) 423 (Interval too brief - expiration time of the resource is too short) |
| Successful | Number of successful initial registrations. This counter is incremented once for each successful initial registration with a 200 OK response. This counter is based on ingress (received) messages only. |
| Unsuccessful | Number of unsuccessful initial registrations.
				  This counter is incremented once for each unsuccessful initial registration
				  when the response to the initial REGISTER has a non-success status code. This
				  counter is based on ingress (received) messages only. Note: This counter is not incremented when registrations are challenged by the following response messages: 401 (Unauthorized - user authentication required) 407 (Proxy authentication required) 423 (Interval too brief - expiration time of the resource is too short) |
| Refresh Registrations | |
| Total | Total number of registrations that were refreshed. This counter is incremented once for every refresh registration. This counter is based on ingress (received) messages only. |
| Successful | Total number of registrations that were successfully refreshed. This counter is incremented once for each successful refresh registration. This counter is based on ingress (received) messages only. |
| Unsuccessful | Total number of registrations that were unsuccessfully refreshed. This counter is incremented once for each unsuccessful refresh registration. This counter is based on ingress (received) messages only. |
| De-Registrations | |
| Total | Total number of registrations that de-registered. This counter is incremented once for every de-registration. This counter is based on ingress (received) messages only. In the event a de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that de-registration message is incremented. |
| Successful | Total number of registrations that successfully de-registered. This counter is incremented once for each successful de-registration. This counter is based on ingress (received) messages only. In the event a successful de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that successful de-registration message is incremented. |
| Unsuccessful | Total number of registrations that unsuccessfully de-registered. This counter is incremented once for each unsuccessful de-registration. This counter is based on ingress (received) messages only. In the event an unsuccessful de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that unsuccessful de-registration message is incremented. |
show enum
Telephone Number Mapping (ENUM) is an IETF standard (RFC 2916) for mapping the public telephone number address space into the Domain Name System (DNS). It links a phone number to an Internet address that is published in the DNS system. This allows a number to be reachable anywhere via the best and cheapest route.
The show enum command displays information about the ENUM Agent. These statistics provide current information only. For associated HDR Group and Group Statistics, see enum-stats.
ORACLE> show enum
09:05:20-106
            ---Queries--- --Successful-- --NotFound--- --Timed Out--
ENUM Agent  Current Total Current  Total Current Total Current Total
| Enum Agent | Name of the ENUM Agent on the OCSBC. |
| Queries Total | Number of ENUM queries |
| Successful Total | Number of successful ENUM queries |
| Not Found Total | Number of ENUM queries returning a not found |
| Times Out Total | Number of ENUM query timeouts |
show h323
H.323 is a recommendation from the ITU Telecommunication Standardization Sector (ITU-T) that defines the protocols to provide audio-visual communication sessions on any packet network. H.323 addresses call signaling and control, multimedia transport and control, and bandwidth control for point-to-point and multi-point calls. The OCSBC responds to and forwards H.323 signaling messages and sets up H.323 sessions based on the system configuration.
The show h323 command displays information about H323 operations. These statistics include H323 information over Period and Lifetime monitoring spans, as well as information on active H323 status. For associated HDR Group and Group Statistics, see h323-stats.
H323D Status displays recent Lifetime monitoring information ONLY.ORACLE> show h323
10:36:07—94
Session Stats        -- Period --    -------- Lifetime -------
Incoming Calls            0     0        0        0      0    0
Outgoing calls            0     0        0        0      0    0
Connected Calls           0     0        0        0      0    0
Incoming Channels         0     0        0        0      0    0
Outgoing Channels         0     0        0        0      0    0
H3230 status         Current   Lifetime
Queued Messages            0          0
TPKT Channels              0          0
UDP Channels               0          0
Load Rate = 0.2
| Session Stats | |
| Incoming Calls | Number of incoming H.323 calls |
| Outgoing Calls | Number of outgoing H.323 calls |
| Connected Calls | Number of connected calls |
| Incoming Channels | Number of established incoming calls |
| Outgoing Channels | Number of established outgoing channels |
| Contexts | Number of established H.323 contexts (or call terminations) |
| H323D Status | |
| Queued Messages | Number of messages queued |
| TPKT Channels | Number of ThroughPacket (TPKT) channels open(ed) |
| UDP Channels | Number of User Datagram Protocol (UDP) channels open(ed) |
| Load Rate | Total H323 current load rate, in seconds, on the OCSBC |
show sipd rate
The show sipd rate command displays request and response rates for messages (per method) on a system-wide basis. The rates are calculated based on the time in the current monitoring window (100+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show sipd rate
17:24:28-103
Method Name  Msg Recv  Msg Sent  Req Recv  Req Sent  Resp Recv  Resp Sent
                 Rate      Rate      Rate      Rate       Rate       Rate
INVITE            0.0       0.0       0.0       0.0        0.0        0.0
ACK               0.0       0.0       0.0       0.0        0.0        0.0
BYE               0.0       0.0       0.0       0.0        0.0        0.0
REGISTER          0.0       0.0       0.0       0.0        0.0        0.0
CANCEL            0.0       0.0       0.0       0.0        0.0        0.0
PRACK             0.0       0.0       0.0       0.0        0.0        0.0
OPTIONS           0.0       0.0       0.0       0.0        0.0        0.0
INFO              0.0       0.0       0.0       0.0        0.0        0.0
SUBSCRIBE         0.0       0.0       0.0       0.0        0.0        0.0
NOTIFY            0.0       0.0       0.0       0.0        0.0        0.0
REFER             0.0       0.0       0.0       0.0        0.0        0.0
UPDATE            0.0       0.0       0.0       0.0        0.0        0.0
MESSAGE           0.0       0.0       0.0       0.0        0.0        0.0
PUBLISH           0.0       0.0       0.0       0.0        0.0        0.0
OTHER             0.0       0.0       0.0       0.0        0.0        0.0
ALL               0.0       0.0       0.0       0.0        0.0        0.0
clank#
show sipd rate agent
The show sipd rate agent command displays request and response rates for messages (per method) for all session agents. By adding a session agent name in the form show sipd rate agent <session-agent-name>, you can view statistics for the identified agent only. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show sipd rate agent 192.168.202.100
17:26:47-42
Session Agent 192.168.202.100
show sipd rate interface
The show sipd rate interface command displays request and response rates for messages (per method) for all configured sip-interfaces. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show sipd rate interface
17:24:33-58
Sip Interface core
17:24:33-58
Sip Interface peer
By entering a configured interface, the ACLI displays aggregate statistics for that interface and then displays all Session Agents’ counts configured on that SIP interface. Displays have been truncated below. For example:
ORACLE# show sipd rate interface peer 17:24:40-34 Sip Interface peer Method Name Msg Recv Msg Sent Req Recv Req Sent Resp Recv Resp Sent Rate Rate Rate Rate Rate Rate INVITE 0.0 0.0 0.0 0.0 0.0 0.0 [...] OTHER 0.0 0.0 0.0 0.0 0.0 0.0 clank# __________________________________________________________________________________ Session Agent 172.16.202.102 Method Name Msg Recv Msg Sent Req Recv Req Sent Resp Recv Resp Sent Rate Rate Rate Rate Rate Rate INVITE 0.0 0.0 0.0 0.0 0.0 0.0 ACK 0.0 0.0 0.0 0.0 0.0 0.0 BYE 0.0 0.0 0.0 0.0 0.0 0.0 REGISTER 0.0 0.0 0.0 0.0 0.0 0.0 CANCEL 0.0 0.0 0.0 0.0 0.0 0.0 PRACK 0.0 0.0 0.0 0.0 0.0 0.0 OPTIONS 0.0 0.0 0.0 0.0 0.0 0.0 INFO 0.0 0.0 0.0 0.0 0.0 0.0 SUBSCRIBE 0.0 0.0 0.0 0.0 0.0 0.0 NOTIFY 0.0 0.0 0.0 0.0 0.0 0.0 REFER 0.0 0.0 0.0 0.0 0.0 0.0 UPDATE 0.0 0.0 0.0 0.0 0.0 0.0 MESSAGE 0.0 0.0 0.0 0.0 0.0 0.0 PUBLISH 0.0 0.0 0.0 0.0 0.0 0.0 OTHER 0.0 0.0 0.0 0.0 0.0 0.0 17:26:21-46 Session Agent 192.168.202.100 Method Name Msg Recv Msg Sent Req Recv Req Sent Resp Recv Resp Sent Rate Rate Rate Rate Rate Rate INVITE 0.0 0.0 0.0 0.0 0.0 0.0 [...] OTHER 0.0 0.0 0.0 0.0 0.0 0.0 ORACLE#
show dnsalg rate
The show dnsalg rate command displays request and response rates for DNS messages on a system-wide basis. The rates are calculated based on the time in the current monitoring window (100+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show dnsalg rate
17:31:21-15
Realm-id  Msg Recv  Msg Sent  Req Recv  Req Sent  Resp Recv  Resp Sent
show dnsalg rate realm-id
The show dnsalg rate realm-id command displays request and response rates for DNS messages on a per-realm basis. If you add a realm-name to the query, that specific realm’s data will be returned. Entered without a realm name, all configured realms will be displayed. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show dnsalg rate realm-id peer
17:31:31-26
peer           0.0       0.0       0.0       0.0        0.0        0.0
show dnsalg rate server-ip-addr
The show dnsalg rate server-ip-addr command displays request and response rates for DNS messages on a per-DNS server basis. If you add a DNS Server IP address to the query, that specific server’s data will be returned. Entered without a server IP address, all configured servers will be displayed. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show dnsalg rate server-ip-addr 172.16.10.5
17:32:19-44
DNS ALG Realm peer
Ip Address             Msg Recv  Msg Sent  Req Recv  Req Sent  Resp Recv  Resp Sent
172.16.10.5                 0.0       0.0       0.0       0.0        0.0        0.0
show enum rate
The show enum rate command displays request and response rates for ENUM messages on a system-wide basis. The rates are calculated based on the time in the current monitoring window (100+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# # show enum rate
17:22:28-23
Config Name  Msg Recv  Msg Sent  Req Recv  Req Sent  Resp Recv  Resp Sent
show enum rate config-name
The show enum rate config-name command displays request and response rates for ENUM messages per ENUM configuration. If you add a an enum-config-name to the query, that specific configuration’s data will be returned. Entered without a name, all configured enum-configs will be displayed. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show enum rate config-name test1
17:22:53-48
test1             0.0       0.0       0.0       0.0        0.0        0.0
show enum rate server-ip-addr
The enum rate server-ip-addr command displays request and response rates for individual enum-servers. If you add an IP address to the query, that specific server’s data will be returned. Entered without a server IP address, all configured servers will be displayed. If an IP address is present in more than one ENUM configuration then the message processing level is displayed separately for each configuration object. The rates are calculated based on the time in the current monitoring window (30+current period elapsed). The Message Received and the Messages sent columns are the sum of the corresponding Requests or responses. For example:
ORACLE# show enum rate server-ip-addr 192.168.201.5
17:24:00-55
ENUM Config Name enum
192.168.201.5         0.0       0.0       0.0       0.0        0.0        0.0
17:24:00-55
ENUM Config Name test1
