ACLI-Associated Groups and Group Statistics
The Groups and Group Statistics in this section correspond to the data that displays as output from some of the current ACLI commands. For example, the output for the show sipd sessions command, when run from the ACLI, is shown in the figure below:
Example of Show Command Output
ORACLE> show sipd sessions
12:50:45-131
SIP Session Status         -- Period -- -------- Lifetime --------
                 Active    High   Total      Total  PerMax    High
Sessions              0       0       0          0       0       0
  Initial             0       0       0          0       0       0
  Early               0       0       0          0       0       0
  Established         0       0       0          0       0       0
  Terminated          0       0       0          0       0       0
Dialogs               0       0       0          0       0       0
  Early               0       0       0          0       0       0
  Confirmed           0       0       0          0       0       0
For the sip-session group, the HDR Collector stores the same data that would display in the Lifetime/Total column if you ran the ACLI command at the same time the Collector sampled the statistics. In the ACLI output, the data is grouped by Sessions and Dialogs. When mapped into the HDR data for the sip-session group header, the ACLI names are further clarified, as shown in the table below:
| ACLI Name | Group Header Name |
| Sessions | Sessions |
| Initial | Sessions Initial |
| Early | Sessions Early |
| Established | Sessions Established |
| Terminated | Sessions Terminated |
| Dialogs | Dialogs |
| Early | Dialogs Early |
| Confirmed | Dialogs Confirmed |
| Terminated | Dialogs Terminated |
The following is an example of a CSV file containing the HDR statistics for the sip-session Group generated by the HDR Collector. The output format reflects that the file was opened using an application compatible with a CSV file.
Example of a CSV File for the sip-session Group
Timestamp Sessions Sessions Initial Sessions Early ... 1301702288 45 45 28 ... 1301702456 35 35 35 ...
The records in a CSV file may display differently, depending on the record data included in the file, and the method used to open the file. For more information about the display of record data in a CSV file, see Appendix A, CSV File Data Formats.This section provides a description of each Group and Group Statistic associated with the ACLI. Each Group table identifies the ACLI Show command for which it is associated, and provides a link to the applicable command in the "HDR Show Commands" chapter.
sip-sessions
Consists of statistics pertaining to the Session Initiation Protocol (SIP) sessions. Use "show sipd sessions" to view statistics.
| Position | Statistic | Type | Timer Value | Range | Description |
| 1 | Sessions | counter | N/A | 0 to 4294967295 | Total number of sessions established by INVITE and SUBSCRIBE messages |
| 2 | Sessions Initial | counter | N/A | 0 to 4294967295 | Total number of sessions for which an INVITE or SUBSCRIBE is being forwarded |
| 3 | Sessions Early | counter | N/A | 0 to 4294967295 | Total number of sessions for which the first provisional response (1xx other than 100) is received. |
| 4 | Sessions Established | counter | N/A | 0 to 4294967295 | Total number of sessions for which a success (2xx) response is received. |
| 5 | Sessions Terminated | counter | N/A | 0 to 4294967295 | Total number of sessions that have ended by receiving or sending a BYE for an Established session or forwarding an error response for an Initial or Early session. The session remains in the terminated state until all the resources for the session are freed up. |
| 6 | Dialogs | counter | N/A | 0 to 4294967295 | Total number of end-to-end SIP signaling connections. |
| 7 | Dialogs Early | counter | N/A | 0 to 4294967295 | Total number of dialogs that were created by a provisional response. |
| 8 | Dialogs Confirmed | counter | N/A | 0 to 4294967295 | Total number of dialogs that were created by a success response. An Early dialog transitions to Confirmed when a success response is received. |
| 9 | Dialogs Terminated | counter | N/A | 0 to 4294967295 | Total number of dialogs that were ended by a receiving/sending of a BYE for an Established session, or a receiving/sending error response Early dialog. The dialog remains in the Terminated state until all the resources for the session are freed up. |
sip-acl-oper
Consists of statistics pertaining to the Session Initiation Protocol (SIP) access control list (ACL) operations. Use "show sipd acls" to view statistics.
| 1 | ACL Requests | counter | N/A | 0 to 4294967295 | Total number of ACL requests |
| 2 | Bad Messages | counter | N/A | 0 to 4294967295 | Total number of bad messages |
| 3 | Promotions | counter | N/A | 0 to 4294967295 | Total number of ACL entry promotions. These are the ACL entries that have been promoted from untrusted to trusted status. |
| 4 | Demotions | counter | N/A | 0 to 4294967295 | Total number of ACL entry demotions. |
| 5 | Demote Trust-Untrust | counter | N/A | 0 to 4294967295 | Total number of ACL entries demoted from trusted to untrusted. |
| 6 | Demote Untrust-Deny | counter | N/A | 0 to 4294967295 | Total number of ACL entries demoted from untrusted to deny. |
sip-acl-status
Consists of statistics pertaining to the Session Initiation Protocol (SIP) access control list (ACL) state. Use "show sipd acls" to view statistics.
| 1 | Total Entries | counter | N/A | 0 to 4294967295 | Total number of ACL entries, both trusted and blocked. |
| 2 | Trusted | counter | N/A | 0 to 4294967295 | Total number of trusted ACL entries |
| 3 | Blocked | counter | N/A | 0 to 4294967295 | Total number of blocked ACL entries |
sip-client
Consists of statistics pertaining to the Session Initiation Protocol (SIP) client state. Use "show sipd client" to view statistics.
| 1 | AllStates | counter | N/A | 0 to 4294967295 | Total number of all client session transactions |
| 2 | Initial | counter | N/A | 0 to 4294967295 | Total number of times the Initial state was entered due to the receipt of a request. |
| 3 | Trying | counter | N/A | 0 to 4294967295 | Total number of times the Trying state was entered due to the receipt of a request |
| 4 | Calling | counter | N/A | 0 to 4294967295 | Total number of times the Calling state was entered due to the receipt of an INVITE request |
| 5 | Proceeding | counter | N/A | 0 to 4294967295 | Total number of times the Proceeding state was entered due to the receipt of a provisional response while in the Calling state |
| 6 | Cancelled | counter | N/A | 0 to 4294967295 | Total number of INVITE transactions that received a CANCEL |
| 7 | EarlyMedia | counter | N/A | 0 to 4294967295 | Total number of times the Proceeding state was entered due to the receipt of a provisional response that contained a Session Description Protocol (SDP) while in the Calling state |
| 8 | Completed | counter | N/A | 0 to 4294967295 | Total number of times that the Completed state was entered due to the receipt of a status code in the range of 300-699 when either in the Calling or Proceeding state |
| 9 | Setmedia | counter | N/A | 0 to 4294967295 | Total number of transactions in which the OCSBC was setting up NAT and steering ports |
| 10 | Established | counter | N/A | 0 to 4294967295 | Total number of times the client received a 2xx response to an INVITE, but could not forward it because the NAT and steering port information was missing |
| 11 | Terminated | counter | N/A | 0 to 4294967295 | Total number of times the Terminated state was entered after a 2xx message |
sip-server
Consists of statistics pertaining to the Session Initiation Protocol (SIP) server state. Use "show sipd server" to view statistics.
| 1 | AllStates | counter | N/A | 0 to 4294967295 | Total number of all server session transactions |
| 2 | Initial | counter | N/A | 0 to 4294967295 | Total number of times the Initial state was entered due to the receipt of a request |
| 4 | Proceeding | counter | N/A | 0 to 4294967295 | Total number of times the Proceeding state was entered due to the receipt of a provisional response while in the Calling state |
| 5 | Cancelled | counter | N/A | 0 to 4294967295 | Total number of INVITE transactions that received a CANCEL |
| 6 | Established | counter | N/A | 0 to 4294967295 | Total number of times the server received a 2xx response to an INVITE, but could not forward it because the NAT and steering port information was missing |
| 7 | Completed | counter | N/A | 0 to 4294967295 | Total number of times that the Completed state was entered due to the receipt of a status code in the range of 300-699 when either in the Calling or Proceeding state |
| 8 | Confirmed | counter | N/A | 0 to 4294967295 | Total number of times that an ACK was received while the server was in the Completed state and then transitioned to Confirmed state |
| 9 | Terminated | counter | N/A | 0 to 4294967295 | Total number of times the Terminated state was entered after a 2xx message, or never received an ACK in the Completed state, and then transitioned to the Terminated state. |
sip-policy
Consists of statistics pertaining to the Session Initiation Protocol (SIP) local policy / routing statistics. Use "show sipd policy" to view statistics.
| 1 | Local Lookup | counter | N/A | 0 to 4294967295 | Total number of local policy lookups |
| 2 | Local Hits | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups |
| 3 | Local Misses | counter | N/A | 0 to 4294967295 | Total number of local policy lookup failures |
| 4 | Local Drops | counter | N/A | 0 to 4294967295 | Total number of local policy lookups where the next hop session agent group is H323 |
| 5 | Agent Group Hits | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups for session agent groups |
| 6 | Agent Group Misses | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups where no session agent was available for the session agent group |
| 7 | No Routes Found | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups, but temporarily unable to route (for example, session agent out of service) |
| 8 | Missing Dialog | counter | N/A | 0 to 4294967295 | Total number of local policy lookups where the dialog was not found for a request addressed to the OCSBC with a To tag or for a NOTIFY-SUBSCRIBE SIP request |
| 9 | Inb SA Constraints | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups where the inbound session agent (SA) exceeded constraints |
| 10 | Outb SA Constraints | counter | N/A | 0 to 4294967295 | Total number of successful local policy lookups where the outbound SA exceeded constraints |
| 11 | Inb REG SA Constraints | counter | N/A | 0 to 4294967295 | Total number of successful inbound local policy lookups where the registrar (REG) SA exceeded constraints |
| 12 | Outb REG SA Constraints | counter | N/A | 0 to 4294967295 | Total number of successful outbound local policy lookups where the registrar (REG) SA exceeded constraints |
| 13 | Requests Challenged | counter | N/A | 0 to 4294967295 | Total number of requests that were challenged. |
| 14 | Challenges Found | counter | N/A | 0 to 4294967295 | Total number of challenges found. |
| 15 | Challenges Not Found | counter | N/A | 0 to 4294967295 | Total number of challenges not found. |
| 16 | Challenge Drops | counter | N/A | 0 to 4294967295 | Total number of challenges dropped. |
sip-errors
Consists of statistics pertaining to errors that occur in SIP media events. Use "show sipd errors" to view statistics.
| 1 | SDP Offer Errors | counter | N/A | 0 to 4294967295 | Total number of errors encountered in setting up the media session for a session description in a SIP request or response which is a Session Description Protocol (SDP) Offer in the Offer/Answer model (RFC 3264) |
| 2 | SDP Answer Errors | counter | N/A | 0 to 4294967295 | Total number of errors encountered in setting up the media session for a session description in a SIP request or response which is a Session Description Protocol (SDP) Answer in the Offer/Answer model (RFC 3264) |
| 3 | Drop Media Errors | counter | N/A | 0 to 4294967295 | Total number of errors encountered in tearing
				  down the media for a dialog or session that is being terminated due to: a) non-successful response to an INVITE transaction, or b) a BYE transaction received from one of the participants in a dialog/session, or c) a BYE initiated by the OCSBC due to a timeout notification from the Middlebox Control Daemon (MBCD). |
| 4 | Transaction Errors | counter | N/A | 0 to 4294967295 | Total number of errors in continuing the processing of the SIP client transaction associated with setting up or tearing down of the media session. |
| 5 | Application Errors | counter | N/A | 0 to 4294967295 | Total number of miscellaneous errors in the SIP application that are otherwise uncategorized |
| 6 | Media Exp Events | counter | N/A | 0 to 4294967295 | Total number of flow timer expiration notifications received from the Middlebox Control Daemon (MBCD). |
| 7 | Early Media Exps | counter | N/A | 0 to 4294967295 | Total number of flow timer expiration notifications received for media sessions that were not completely set up due to an incomplete or pending INVITE transaction |
| 8 | Exp Media Drops | counter | N/A | 0 to 4294967295 | Total number of flow timer expiration notifications from the Middlebox Control Daemon (MBCD) that resulted in the termination of the dialog/session by the SIP application. |
| 9 | Expired Sessions | counter | N/A | 0 to 4294967295 | Total number of sessions terminated due to the session timer expiring |
| 10 | Multiple OK Drops | counter | N/A | 0 to 4294967295 | Total number of dialogs terminated upon reception of a 200 OK response from multiple User Agent Servers (UASs) for a given INVITE transaction that was forked by a downstream proxy |
| 11 | Multiple OK Terms | counter | N/A | 0 to 4294967295 | Total number of dialogs terminated upon reception of a 200 OK response that conflicts with an existing established dialog on the OCSBC |
| 12 | Media Failure Drops | counter | N/A | 0 to 4294967295 | Total number of dialogs terminated due to a failure in establishing the media session. |
| 13 | Non-ACK 2xx Drops | counter | N/A | 0 to 4294967295 | Total number of sessions terminated because an ACK was not received for a 2xx response |
| 14 | Invalid Requests | counter | N/A | 0 to 4294967295 | Total number of invalid requests (for example, an unsupported header was received). |
| 15 | Invalid Responses | counter | N/A | 0 to 4294967295 | Total number of invalid responses (for example, no Via header in response) |
| 16 | Invalid Messages | counter | N/A | 0 to 4294967295 | Total number of messages dropped due to parse failure |
| 17 | CAC Session Drop | counter | N/A | 0 to 4294967295 | Total number of call admission control (CAC) session setup failures |
| 18 | CAC BW Drop | counter | N/A | 0 to 4294967295 | Total number of call admission control (CAC) session setup failures due to insufficient bandwidth (BW) |
| 19 | Call Rejects | counter | N/A | 0 to 4294967295 | Total number of calls rejected during the window. |
sip-status
Consists of statistics pertaining to Session Initiation Protocol (SIP) transactions. Use "show sipd status" to view statistics.
| 1 | Sessions | counter | N/A | 0 to 4294967295 | Total number of sessions established by INVITE messages |
| 2 | Subscriptions | counter | N/A | 0 to 4294967295 | Total number of sessions established by SUBSCRIBE messages |
| 3 | Dialogs | counter | N/A | 0 to 4294967295 | Total number of end-to-end SIP signaling connections |
| 4 | CallID Maps | counter | N/A | 0 to 4294967295 | Total number of successful session header Call ID mappings |
| 5 | Rejections | counter | N/A | 0 to 4294967295 | Total number of rejected INVITEs |
| 6 | ReINVITEs | counter | N/A | 0 to 4294967295 | Total number of ReINVITEs |
| 7 | Media Sessions | counter | N/A | 0 to 4294967295 | Total number of successful media sessions |
| 8 | Media Pending | counter | N/A | 0 to 4294967295 | Total number of media sessions waiting to be established |
| 9 | Client Trans | counter | N/A | 0 to 4294967295 | Total number of client transactions |
| 10 | Server Trans | counter | N/A | 0 to 4294967295 | Total number of server transactions that have taken place on the OCSBC |
| 11 | Resp Contexts | counter | N/A | 0 to 4294967295 | Total number of response contexts |
| 12 | Saved Contexts | counter | N/A | 0 to 4294967295 | Total number of saved contexts |
| 13 | Sockets | counter | N/A | 0 to 4294967295 | Total number of SIP sockets |
| 14 | Req Drops | counter | N/A | 0 to 4294967295 | Total number of dropped requests |
| 15 | DNS Trans | counter | N/A | 0 to 4294967295 | Total number of Domain Name System (DNS) transactions |
| 16 | DNS Sockets | counter | N/A | 0 to 4294967295 | Total number of Domain Name System (DNS) sockets |
| 17 | DNS Results | counter | N/A | 0 to 4294967295 | Total number of Domain Name System (DNS) results |
| 18 | Session Rate | fixed decimal | 30 | 0 to 4294967295 | The rate, per second, of SIP invites allowed to or from the OCSBC during the sliding window period. The rate is computed every 10 seconds . |
| 19 | Load Rate | guage | 30 | 0% to 100% | Average Central Processing Unit (CPU) utilization of the OCSBC during the current window. The average is computed every 10 seconds unless the load-limit is configured in the SIPConfig record, in which case it is 5 seconds. |
| 20 | Active Subscriptions | counter | N/A | 0 to 4294967295 | specifies the current global count of active SIP subscriptions. |
| 21 | SubscriptionsPerMax | counter | N/A | 0 to 4294967295 | specifies the maximum global count of SIP subscriptions initiated during any 100 second period since the last SBC re-boot. |
| 22 | Subscriptions High | counter | N/A | 0 to 4294967295 | specifies the maximum global count of active SIP subscriptions since the last SBC re-boot. |
sip-invites
Consists of statistics pertaining to Session Initiation Protocol (SIP) INVITEs. Use "show sipd invite" to view statistics.
| 1 | INVITE Requests | counter | N/A | 0 to 4294967295 | Total number of INVITE requests |
| 2 | Retrans | counter | N/A | 0 to 4294967295 | Total number of retransmissions of INVITEs |
| 3 | Response Retrans | counter | N/A | 0 to 4294967295 | Total number of response retransmissions |
| 4 | Transaction Timeouts | counter | N/A | 0 to 4294967295 for client. Server values are always “—”; transaction timeout statistics are not valid for server operations. | Total number of INVITE request transaction timeouts |
| 5 | Locally Throttled | counter | N/A | 0 to 4294967295 for client. Server values are always “—”; locally throttled statistics are not valid for server operations. | Total number of INVITE requests locally throttled |
registration-realm
Statistics that display registration information (counters) for the total registrations received, number of successful registrations, and number of unsuccessful registrations for each of the following categories: initial registrations, refresh registrations, and de-registrations. Use "show sipd realms" to view statistics.
| 1 | Realm Name | config | N/A | N/A | Name of the realm for which the group statistics are being calculated. |
| 2 | Total Initial Registrations | counter | N/A | 0 to 4294967295 | Total number of initial registrations. This
				  counter is incremented once for each initial REGISTER message even when the
				  REGISTER is challenged. This counter is based on ingress (received) messages
				  only. Note: This counter is not incremented when registrations are challenged by the following response messages: 401 (Unauthorized - user authentication required) 407 (Proxy authentication required) 423 (Interval too brief - expiration time of the resource is too short) |
| 3 | Successful Initial Registrations | counter | N/A | 0 to 4294967295 | Number of successful initial registrations. This counter is incremented once for each successful initial registration with a 200 OK response. This counter is based on ingress (received) messages only. |
| 4 | Unsuccessful Initial Registrations | counter | N/A | 0 to 4294967295 | Number of unsuccessful initial registrations.
				  This counter is incremented once for each unsuccessful initial registration
				  when the response to the initial REGISTER has a non-success status code. This
				  counter is based on ingress (received) messages only. Note: This counter is not incremented when registrations are challenged by the following response messages: 401 (Unauthorized - user authentication required) 407 (Proxy authentication required) 423 (Interval too brief - expiration time of the resource is too short) |
| 5 | Total Refresh Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that were refreshed. This counter is incremented once for every refresh registration. This counter is based on ingress (received) messages only. |
| 6 | Successful Refresh Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that were successfully refreshed. This counter is incremented once for each successful refresh registration. This counter is based on ingress (received) messages only. |
| 7 | Unsuccessful Refresh Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that were unsuccessfully refreshed. This counter is incremented once for each unsuccessful refresh registration. This counter is based on ingress (received) messages only. |
| 8 | Total De-Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that de-registered. This counter is incremented once for every de-registration. This counter is based on ingress (received) messages only. In the event a de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that de-registration message is incremented. |
| 9 | Successful De-Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that successfully de-registered. This counter is incremented once for each successful de-registration. This counter is based on ingress (received) messages only. In the event a successful de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that successful de-registration message is incremented. |
| 10 | Unsuccessful De-Registrations | counter | N/A | 0 to 4294967295 | Total number of registrations that unsuccessfully de-registered. This counter is incremented once for each unsuccessful de-registration. This counter is based on ingress (received) messages only. In the event an unsuccessful de-registration message is received on a realm that is different than that of the initial registration message, the de-registration counter for the ingress realm of that unsuccessful de-registration message is incremented. |
enum-stats
Consists of statistics pertaining to the Telephone Number Mapping (ENUM) Agent on the OCSBC. Use show enum to view statistics.
| 1 | Enum Agent | config | N/A | N/A | Name of the ENUM Agent |
| 2 | Queries Total | counter | N/A | 0 to 4294967295 | Total number of ENUM queries |
| 3 | Successful Total | counter | N/A | 0 to 4294967295 | Total number of successful ENUM queries |
| 4 | Not found Total | counter | N/A | 0 to 4294967295 | Total number of ENUM queries returning a not found |
| 5 | Timeout Total | counter | N/A | 0 to 4294967295 | Total number of ENUM query timeouts |
h323-stats
Consists of statistics pertaining to H323 events on the OCSBC. Use show h323 to view statistics.
| 1 | Incoming Calls | counter | N/A | 0 to 4294967295 | Total number of incoming H.323 calls |
| 2 | Outgoing Calls | counter | N/A | 0 to 4294967295 | Total number of outgoing H.323 calls |
| 3 | Connected Calls | counter | N/A | 0 to 4294967295 | Total number of connected H.323 calls |
| 4 | Incoming Channels | counter | N/A | 0 to 4294967295 | Total number of established incoming calls |
| 5 | Outgoing Channels | counter | N/A | 0 to 4294967295 | Total number of established outgoing calls |
| 6 | Contexts | counter | N/A | 0 to 4294967295 | Total number of established H.323 contexts (or call terminations) |
| 7 | Queued Messages | counter | N/A | 0 to 4294967295 | Total number of messages queued |
| 8 | TPKT Channels | counter | N/A | 0 to 4294967295 | Total number of ThroughPacket (TPKT) channels open(ed) |
| 9 | UDP Channels | counter | N/A | 0 to 4294967295 | Total number of User Datagram Protocol (UDP) channels open(ed) |
tscf-stats
Consists of statistics pertaining to TSCF. Use "show tscf stats" to view statistics.
| Statistic | Data Type | Description |
| Time Stamp | counter | Time Stamp |
| Active Tunnels | gauge (0-2^32-1) | Number of active tunnels |
| Established Tunnels | counter | Number of established tunnels |
| Finished Tunnels | counter | Number of finished tunnels |
| Released Tunnels | counter | Number of released tunnels |
| Max Active Tunnels | counter | Maximum number of active tunnels |
| Total number of tunnels timed out | counter | Total number of timed out tunnels |
| Config requests received | counter | Number of config requests received |
| Nagle option requests | counter | Number of config requests with nagle received |
| Config responses sent | counter | Number of config responses sent |
| Config release requests received | counter | Number of config release requests received |
| Config release responses sent | counter | Number of config release responses sent |
| Client service requests received | counter | Total number of client service requests received |
| Client service responses sent | counter | Number of client service responses sent |
| Enable DDT requests | counter | Number of Dynamic Datagram Tunnel enable client service responses received |
| Disable DDT requests | counter | Number of Dynamic Datagram Tunnel Disable client service responses received |
| Enable redundancy requests | counter | Number of Dynamic Datagram Tunnel Enable client service responses received |
| Disable redundancy requests | counter | Number of Dynamic Datagram Tunnel disable client service responses received |
| Failed Tunnels-Malformed Requests | counter | Number of failed tunnels due to malformed requests |
| Unknown Control messages | counter | Number of failed tunnels due to unknown control messages |
| Client assigned internal IP | counter | Number of failed tunnels due to client assigned internal IP addresses |
| Cannot provision internal IP | counter | Number of failed tunnels due to internal IP that cannot be provisioned |
| Internal IP already provisioned | counter | Number of failed tunnels due to internal IP addresses that are already provisioned |
| Internal IP error | counter | Number of failed tunnels due to general IP error |
| Client assigned internal IP mask | counter | Number of failed tunnels due to internal IP masks assigned by client |
| Cannot provision internal IP mask | counter | Number of failed tunnels due to IP masks that cannot be provisioned |
| Internal IP mask already provisioned | counter | Number of failed tunnels due to internal IP masks already provisioned |
| Internal IP mask error | counter | Number of failed tunnels due to General IP mask error |
| Client assigned SIP server address | counter | Number of failed tunnels due to client assigned SIP server addresses |
| Cannot provision SIP server address | counter | Number of failed tunnels due to not being able to provision SIP server addresses |
| SIP server address already provisioned | counter | Number of failed tunnels due to SIP server address already provisioned |
| SIP server address error | counter | Number of failed tunnels due to SIP server general address errors |
| Client assigned Keep Alive value | counter | Number of failed tunnels due to client assigned keep alive values |
| Cannot provision Keep Alive value | counter | Number of failed tunnels not being able to provision keep alive values |
| Keep Alive value already provisioned | counter | Number of failed tunnels due to keep alive value already provisioned |
| Keep alive value error | counter | Number of failed tunnels due to keep alive value errors |
| Failed Tunnels - Non Existing Tunnel Id | counter | Number of failed tunnels due to non-existing tunnel IDs |
| Failed Tunnels - Out of Resources | counter | Number of failed tunnels due to a lack of resources |
| Failed Tunnels - Internal IP address exhausted | counter | Number of failed tunnels due to tunnel ID exhaustion |
| Failed Tunnels - Non null IP address | counter | Number of failed tunnels due to non null IP address |
| Failed Tunnels - Non null IP mask | counter | Number of failed tunnels due to non null IP mask |
| Failed Tunnels - Non Null SIP server | counter | Number of failed tunnels due to non null SIP server |
| Failed Tunnels - Non zero keep alive | counter | Number of failed tunnels due to non zero keep alive |
| Failed Tunnels - No listening socket | counter | Number of failed tunnels due to a missing (listening socket?) file description |
| Failed Tunnels - Server Failure | counter | Number of failed tunnels due to server failure |
| Failed Tunnels - Redundancy not enabled | counter | Number of failed tunnels due to disabled redundancy feature |
| Failed Tunnels - Redundancy factor limit exceeded | counter | Number of failed tunnels due to redundancy factor limit being exceeded on server |
| Failed Tunnels - Tunnel Id exhausted | counter | Number of failed tunnels due to tunnel ID exhausted on server |
| Failed Tunnels - Timer failures | counter | Number of failed tunnels due to timer failure on server |
| Failed Tunnels - DDT service not enabled | counter | Number of failed tunnels due to Dynamic Datagram Tunnel not being enabled on serve |
| Failed Tunnels - DDT request on wrong transport | counter | Number of failed tunnels due to Dynamic Datagram Tunnel request wrong transport on the server |
| Failed Tunnels - DDT service only fordatagram transport | counter | Number of failed tunnels due to Dynamic Datagram Tunnel service being available only on datagram transports |
| Failed Tunnels - Inconsistent transport for DDT | counter | Number of failed tunnels due to inconsistent transport for Dynamic Datagram Tunnel on server |
| Failed Tunnels - Unknown service type requested | counter | Number of failed tunnels due to unknown service type requested on server |
| Failed Tunnels - Incorrect CM for established tunnel | counter | Number of failed tunnels due to incorrect control messages for established tunnels on server |
| Failed Tunnels - Address pool unavailable | counter | Number of failed tunnels due to unavailable address pools on server |
| Failed Tunnels - No listening socket | counter | Number of failed tunnels due to a unavailable (listening socket?) file descriptor on server |
| Failed Tunnels - Versions Not Supported | counter | Number of failed tunnels due to version not being supported |
| Failed Tunnels - License Exceeded | counter | Number of failed tunnels due to exceeding the TSCF license/entitlement limit |
| Packets sent to unused TSCF IP address | counter | Number of packets dropped due to being sent to an unused TSCF IP address |
| Control messages with wrong sequence number | counter | Number of control messages with a wrong sequence number |
| Config requests dropped due to license limit | counter | Number of config requests dropped due to the TSCF license limit |
| Config requests dropped due to per interface limit | counter | Number of config requests dropped due to per interface limit |
| Stats memory allocations | counter | Number of stats memory allocations |
| Packets dropped due to inter-client c0mmunication | counter | Number of packets dropped due to inter-client c0mmunication |
| Stats memory frees | counter | Number of stats memory frees |
| Stats memory allocations failures | counter | Number of stats memory allocation failures |
| Switches to Active system | counter | Number of times existing tunnels were switched to Active system |
| Switched to Stand by system | counter | Number of times existing tunnels were switched to Stand-by system |
| Get DTLS Context Requests | counter | Number of times a successful Get Datagram Transport Layer Security context request was sent |
| Get DTLS Context Request Success | counter | Number of successful Datagram Transport Layer Security context request were sent |
| Get DTLS Context Request Failure | counter | Number of Get Datagram Transport Layer Security Context Request failed |
| Set DTLS Context Requests | counter | Number of Set Datagram Transport Layer Security Context Requests were sent |
| Set DTLS Context Requests Success | counter | Number of successful Set Datagram Transport Layer Security Context Requests were sent |
| Set DTLS Context Request Failure | counter | Number of Set Datagram Transport Layer Security Context Request failed |
| FD Table size | Gauge (0-2^32-1) | The current number of entries in the File Descriptor Table |
| Address Table Size | Gauge (0-2^32-1) | The current number of entries in the Address Table |
| Tunnel Table Size | Gauge (0-2^32-1) | The current number of entries in the Tunnel Table |
| Active Tunnel Table Size | Gauge (0-2^32-1) | The current number of entries in the Active Tunnel Table |
| Peer Tunnel Table Size | Gauge (0-2^32-1) | The current number of entries in the Peer Tunnel Table |
| Peer Table Size | Gauge (0-2^32-1) | The current number of entries in the Peer Table |
| Flow ID Table Size | Gauge (0-2^32-1) | The current number of entries in the Flow ID Table |
| License Tunnel Count | Gauge (0-2^32-1) | The current number of Licensed Tunnels ?????? |
| Specific address count | Gauge (0-2^32-1) | Total number of specific address allocation requests |
| Total number tunneled packet drops | counter | Total number of specific address allocation requests |
| Total number untunneled packet drops | counter | Total number of un-tunneled packet drops |
sip-rate
Records SIP processing level in terms of messages per method (i.e. both request and response) per second on system-wide basis.
| 1 | Method Name | string | N/A | N/A | SIP method name for which the group statistics are being calculated |
| 2 | Messages Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for messages received for a SIP method on all SIP interfaces |
| 3 | Messages Sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for messages sent for a SIP method on all SIP interfaces |
| 4 | Requests Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for requests received for a SIP method on all SIP interfaces |
| 5 | Requests Sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for requests sent for a SIP method on all SIP interfaces |
| 6 | Responses Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for responses received for a SIP method on all SIP interfaces |
| 7 | Responses sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for responses sent for a SIP method on all SIP interfaces |
sip-rate-per-interface
Records SIP message rates l in terms of messages per method (i.e. both request and response) per second per SIP interface.
| 1 | Interface Name | string | N/A | N/A | SIP interface where these statistics are being calculated |
| 2 | Method Name | string | N/A | N/A | SIP method name for which the group statistics are being calculated |
| 3 | Messages Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for messages received for a SIP method on all SIP interfaces |
| 4 | Messages Sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for messages sent for a SIP method on all SIP interfaces |
| 5 | Requests Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for requests received for a SIP method on all SIP interfaces |
| 6 | Requests Sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for requests sent for a SIP method on all SIP interfaces |
| 7 | Responses Received Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for responses received for a SIP method on all SIP interfaces |
| 8 | Responses sent Rate | counter | N/A | 0.0 to 429496729.5 | Messages per second for responses sent for a SIP method on all SIP interfaces |
sip-rate-per-agent
Records SIP message rates in terms of messages per method (i.e. both request and response) per second per SIP session agent.
| 1 | Agent Name | string | N/A | N/A | SIP Agent where these statistics are being calculated |
dnsalg-rate
Records DNS Message rate (i.e. both request and response) per second on system-wide basis.
| 1 | Messages Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for all DNS messages received by the system |
| 2 | Messages Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for all DNS messages sent on the system |
| 3 | Requests Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS requests received on the system. |
| 4 | Requests Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS requests sent by the system. |
| 5 | Responses Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS responses received on the system. |
| 6 | Responses sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS responses sent by the system. |
enum-rate
Records ENUM Message rate (i.e. both request and response) per second on system-wide basis.
| 1 | Messages Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages received by the system |
| 2 | Messages Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages sent on the system |
| 3 | Requests Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests received on the system. |
| 4 | Requests Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests sent by the system. |
| 5 | Responses Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses received on the system. |
| 6 | Responses sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses sent by the system. |
dnsalg-rate-per-addr
| 1 | Server IP Address | string | N/A | N/A | DNS Server Address for which the group statistics are being calculated |
| 2 | Messages Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for all DNS messages received by the system |
| 3 | Messages Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for all DNS messages sent on the system |
| 4 | Requests Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS requests received on the system. |
| 5 | Requests Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS requests sent by the system. |
| 6 | Responses Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS responses received on the system. |
| 7 | Responses sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for DNS responses sent by the system. |
enum-rate
enum-rate-per-name
Records ENUM Message rate (i.e. both request and response) per second on per-interface (i.e. the network interface on which the ENUM config's realm exists) basis.
| 1 | ENUM Config Name | string | N/A | N/A | Enum config name for which the group statistics are being calculated |
| 2 | Messages Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages received by this configuration object. |
| 3 | Messages Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages by this configuration object. |
| 4 | Requests Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests received by this configuration object. |
| 5 | Requests Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests sent by this configuration object. |
| 6 | Responses Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses received by this configuration object. |
| 7 | Responses sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses sent by this configuration object. |
enum-rate-per-addr
Records ENUM Message rate (i.e. both request and response) per second on system-wide basis. Records ENUM Message rate (i.e. both request and response) per second on a per-address basis (i.e. ENUM server provisioned in the ENUM Config).
| 1 | Server IP Address | string | N/A | N/A | ENUM Server Address for which the group statistics are being calculated |
| 2 | Messages Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages received by this server. |
| 3 | Messages Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for all ENUM messages sent by this server. |
| 4 | Requests Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests received by this server. |
| 5 | Requests Sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM requests sent by this server. |
| 6 | Responses Received Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses received by this server. |
| 7 | Responses sent Rate | counter | N/A | 0 to 4294967295 | Messages per second for ENUM responses sent by this server. |
show-memory-sobjects
Records memory use reported by the ACLI's show memory sobjects command's data. Records appear in the format <time stamp>,<class name>,<count> where class-name is the name of each sobject, and count is the number of objects currently being used by the application. These records always includes all applicable objects, which number in the hundreds, even when their current count is zero.
sip-method
This HDR group identifies global counts for listed responses to SIP Methods across the system. sip-method is this HDR group's configured name. These counters are otherwise retrieved at the ACLI with the show sipd <method> command. Although this HDR group delivers the same information in the apSipMethodStatsTable (1.3.6.1.4.1.9148.3.15.1.2.10) in ap-sip.mib, the HDR is a contiguous output whereas the MIB table is delivered tabularly.
| CSV position | HDR Column Name | Description |
| 1 | TimeStamp | Timestamp of this HDR record |
| 2 | Message/Event | Name of the SIP Method |
| 3 | Request Server Total | Total number of server requests. |
| 4 | Request Client Total | Total number of client requests. |
| 5 | Retransmissions Server Total | Total number of server retransmission requests. |
| 6 | Retransmissions Client Total | Total number of client retransmission requests. |
| 7 | 100 Trying Server Total | Total number of 100 Trying server response |
| 8 | 100 Trying Client Total | Total number of 100 Trying client response |
| 9 | 180 Ringing Server Total | Total number of 180 Ringing server response. |
| 10 | 180 Ringing Client Total | Total number of 180 Ringing client response. |
| 11 | 181 Forward Server Total | Total number of 181 Forward server response. |
| 12 | 181 Forward Client Total | Total number of 181 Forward client response. |
| 13 | 182 Queued Server Total | Total number of Invite 182 Queued Server response |
| 14 | 182 Queued Client Total | Total number of 182 Queued client response. |
| 15 | 183 Progress Server Total | Total Invite 182 Queued Server response |
| 16 | 183 Progress Client Total | Total number of 183 Progress client response. |
| 17 | 1xx Server Total | Total number of 1xx server response |
| 18 | 1xx Client Total | Total number of 1xx client response |
| 19 | 200OK Server Total | Total number of 200OK server response |
| 20 | 200OK Client Total | Total number of 200OK client response |
| 21 | 202 Accepted Server Total | Total number of 202Accepted server response |
| 22 | 202 Accepted Client Total | Total number of 202 Accepted client response |
| 23 | 2xx Success Server Total | Total number of 2xx Success server response |
| 24 | 2xx Client Total | Total number of 2xx Success client response |
| 25 | 30x Moved Server Total | Total number of 30x Moved server response |
| 26 | 30x Moved Client Total | Total number of 30x Moved client response |
| 27 | 305 Use ProxyServer Total | Total number of 305 Use Proxy server response |
| 28 | 305 Use ProxyClient Total | Total number of 305 Use Proxy client response |
| 29 | 380 Alternative Server Total | Total number of 380 Alternative server response |
| 30 | 380 Alternative Client Total | Total number of 380 Alternative client response |
| 31 | 3xx Redirect Server Total | Total number of 3xx Redirect server response. |
| 32 | 3xx Redirect Client Total | Total number of 3xx Redirect client response. |
| 33 | 400 Bad Request Server Total | Total number of 400 Bad Request server response. |
| 34 | 400 Bad Request Client Total | Total number of 400 Bad Request client response. |
| 35 | 401 Unauthorized Server Total | Total number of 401 Unauthorized server response. |
| 36 | 401 Unauthorized Client Total | Total number of 401 Unauthorized client response. |
| 37 | 403 Forbidden Server Total | Total number of 403 Forbidden server response. |
| 38 | 403 Forbidden Client Total | Total number of 403 Forbidden client response. |
| 39 | 404 Not Found Server Total | Total number of 404 Not Found server response. |
| 40 | 404 Not Found Client Total | Total number of 404 Not Found client response. |
| 41 | 405 Not Allowed Server Total | Total number of 405 Not Allowed server response. |
| 42 | 405 Not Allowed Client Total | Total number of 405 Not Allowed client response. |
| 43 | 406 Not Acceptable Server Total | Total number of 406 Not Acceptable server response. |
| 44 | 406 Not Acceptable Client Total | Total number of 406 Not Acceptable client response. |
| 45 | 407 Proxy Auth Req Server Total | Total number of 407 Proxy Auth Req server response. |
| 46 | 407 Proxy Auth Req Client Total | Total number of 407 Proxy Auth Req client response. |
| 47 | 408 Request Timeout Server Total | Total number of 408 Request Timeout server response. |
| 48 | 408 Request Timeout Client Total | Total number of 408 Request Timeout client response. |
| 49 | 415 Bad Media Type Server Total | Total number of 415 Bad Media Type server response. |
| 50 | 415 Bad Media Type Client Total | Total number of 415 Bad Media Type client response. |
| 51 | 420 Bad Extension Server Total | Total number of 420 Bad Extension server response. |
| 52 | 420 Bad Extension Client Total | Total number of 420 Bad Extension client response. |
| 53 | 421 Extension Reqd Server Total | Total number of 421 Extension Reqd server response. |
| 54 | 421 Extension Reqd Client Total | Total number of 421 Extension Reqd client response. |
| 55 | 422 Too Short Server Total | Total number of 422 Too Short server response. |
| 56 | 422 Too Short Client Total | Total number of 422 Too Short client response. |
| 57 | 423 Too Brief Server Total | Total number of 423 Too Brief server response. |
| 58 | 423 Too Brief Client Total | Total number of 423 Too Brief client response. |
| 59 | 480 Unavailable Server Total | Total number of 480 Unavailable server response. |
| 60 | 480 Unavailable Client Total | Total number of 480 Unavailable client response. |
| 61 | 481 Does Not Exist Server Total | Total number of 481 Does Not Exist server response. |
| 62 | 481 Does Not Exist Client Total | Total number of 481 Does Not Exist client response. |
| 63 | 482 Loop Detected Server Total | Total number of 482 Loop Detected server response. |
| 64 | 482 Loop Detected Client Total | Total number of 482 Loop Detected client response. |
| 65 | 483 Too Many Hops Server Total | Total number of 483 Too Many Hops server response. |
| 66 | 483 Too Many Hops Client Total | Total number of 483 Too Many Hops client response. |
| 67 | 484 Address Incompl Server Total | Total number of 484 Address Incompl server response. |
| 68 | 484 Address Incompl Client Total | Total number of 484 Address Incompl client response. |
| 69 | 485 Ambiguous Server Total | Total number of 485 Ambiguous server response. |
| 70 | 485 Ambiguous Client Total | Total number of 485 Ambiguous client response. |
| 71 | 486 Busy Here Server Total | Total number of 486 Busy Here server response. |
| 72 | 486 Busy Here Client Total | Total number of 486 Busy Here client response. |
| 73 | 486 Busy Here Server Total | Total number of 486 Busy Here server response. |
| 74 | 486 Busy Here Client Total | Total number of 486 Busy Here client response. |
| 75 | 487 Terminated Server Total | Total number of 487 Terminated server response. |
| 76 | 487 Terminated Client Total | Total number of 487 Terminated client response. |
| 77 | 488 Not Acceptable Server Total | Total number of 488 Not Acceptable server response. |
| 78 | 488 Not Acceptable Client Total | Total number of 488 Not Acceptable client response. |
| 79 | 489 Bad Event Server Total | Total number of 489 Bad Event server response. |
| 80 | 489 Bad Event Client Total | Total number of 489 Bad Event client response. |
| 81 | 491 Req Pending Server Total | Total number of 491 Req Pending server response. |
| 82 | 491 Req Pending Client Total | Total number of 491 Req Pending client response. |
| 83 | 4xx Server Total | Total number of 4xx error server response. |
| 84 | 4xx Client Total | Total number of 4xx error client response. |
| 85 | 500 Internal Error Server Total | Total number of 500 Internal Error server response. |
| 86 | 500 Internal Error Client Total | Total number of 500 Internal Error client response. |
| 87 | 501 Not Implemented Server Total | Total number of 501 Not Implemented error server response. |
| 88 | 501 Not Implemented Client Total | Total number of 501 Not Implemented error client response. |
| 89 | 502 Bad Gateway Server Total | Total number of 502 Bad Gateway error server response. |
| 90 | 502 Bad Gateway Client Total | Total number of 502 Bad Gateway error client response. |
| 91 | 503 Service Unavail Server Total | Total number of 503 Service Unavail error server response. |
| 92 | 503 Service Unavail Client Total | Total number of 503 Service Unavail error client response. |
| 93 | 504 Gateway Timeout Server Total | Total number of 504 Gateway Timeout error server response. |
| 94 | 504 Gateway Timeout Client Total | Total number of 504 Gateway Timeout error client response. |
| 95 | 513 Msg Too Large Server Total | Total number of 513 Msg Too Large error server response. |
| 96 | 513 Msg Too Large Client Total | Total number of 513 Msg Too Large error client response. |
| 97 | 580 Precon Failure Server Total | Total number of 580 Precon Failure error server response. |
| 98 | 580 Precon Failure Client Total | Total number of 580 Precon Failure error client response. |
| 99 | 5xx Server Total | Total number of 5xx error server response. |
| 100 | 5xx Client Total | Total number of 5xx error client response. |
| 101 | 600 Busy Everywhere Server Total | Total number of 600 Busy Everywhere error server response. |
| 102 | 600 Busy Everywhere Client Total | Total number of 600 Busy Everywhere error client response. |
| 103 | 603 Decline Server Total | Total number of 603 Decline error server response. |
| 104 | 603 Decline Client Total | Total number of 603 Decline error client response. |
| 105 | 604 Not Found Server Total | Total number of 604 Not Found error server response. |
| 106 | 604 Not Found Client Total | Total number of 604 Not Found error client response. |
| 107 | 606 Not Acceptable Server Total | Total number of 606 Not Acceptable error server response. |
| 108 | 606 Not Acceptable Client Total | Total number of 606 Not Acceptable error client response. |
| 109 | 6xx Server Total | Total number of 6xx error server response. |
| 110 | 6xx Client Total | Total number of 6xx error client response. |
| 111 | Response Retrans Server Total | Total number of server Response retransmission requests |
| 112 | Response Retrans Client Total | Total number of client Response retransmission requests |
| 113 | Transaction Timeouts Server Total | Total number of server transaction timeouts. |
| 114 | Transaction Timeouts Client Total | Total number of client transaction timeouts. |
sip-realm-method
This HDR group identifies global counts for listed responses to SIP Methods across a chosen realm. sip-realm-method is this HDR group's configured name.
| 1 | TimeStamp | Timestamp of this HDR record. |
| 2 | Realm | Name of this realm. |
| 3 | Message/Event | Name of the SIP Method. |
| 4 | Request Server Total | Total number of server requests. |
| 5 | Request Client Total | Total number of client requests. |
| 6 | Retransmissions Server Total | Total number of server retransmission requests. |
| 7 | Retransmissions Client Total | Total number of client retransmission requests. |
| 8 | 100 Trying Server Total | Total number of 100 Trying server response |
| 9 | 100 Trying Client Total | Total number of 100 Trying client response |
| 10 | 180 Ringing Server Total | Total number of 180 Ringing server response. |
| 11 | 180 Ringing Client Total | Total number of 180 Ringing client response. |
| 12 | 181 Forward Server Total | Total number of 181 Forward server response. |
| 13 | 181 Forward Client Total | Total number of 181 Forward client response. |
| 14 | 182 Queued Server Total | Total number of Invite 182 Queued Server response |
| 15 | 182 Queued Client Total | Total number of 182 Queued client response. |
| 16 | 183 Progress Server Total | Total Invite 182 Queued Server response |
| 17 | 183 Progress Client Total | Total number of 183 Progress client response. |
| 18 | 1xx Server Total | Total number of 1xx server response |
| 19 | 1xx Client Total | Total number of 1xx client response |
| 20 | 200OK Server Total | Total number of 200OK server response |
| 21 | 200OK Client Total | Total number of 200OK client response |
| 22 | 202 Accepted Server Total | Total number of 202Accepted server response |
| 23 | 202 Accepted Client Total | Total number of 202 Accepted client response |
| 24 | 2xx Success Server Total | Total number of 2xx Success server response |
| 25 | 2xx Client Total | Total number of 2xx Success client response |
| 26 | 30x Moved Server Total | Total number of 30x Moved server response |
| 27 | 30x Moved Client Total | Total number of 30x Moved client response |
| 28 | 305 Use ProxyServer Total | Total number of 305 Use Proxy server response |
| 29 | 305 Use ProxyClient Total | Total number of 305 Use Proxy client response |
| 30 | 380 Alternative Server Total | Total number of 380 Alternative server response |
| 31 | 380 Alternative Client Total | Total number of 380 Alternative client response |
| 32 | 3xx Redirect Server Total | Total number of 3xx Redirect server response. |
| 33 | 3xx Redirect Client Total | Total number of 3xx Redirect client response. |
| 34 | 400 Bad Request Server Total | Total number of 400 Bad Request server response. |
| 35 | 400 Bad Request Client Total | Total number of 400 Bad Request client response. |
| 36 | 401 Unauthorized Server Total | Total number of 401 Unauthorized server response. |
| 37 | 401 Unauthorized Client Total | Total number of 401 Unauthorized client response. |
| 38 | 403 Forbidden Server Total | Total number of 403 Forbidden server response. |
| 39 | 403 Forbidden Client Total | Total number of 403 Forbidden client response. |
| 40 | 404 Not Found Server Total | Total number of 404 Not Found server response. |
| 41 | 404 Not Found Client Total | Total number of 404 Not Found client response. |
| 42 | 405 Not Allowed Server Total | Total number of 405 Not Allowed server response. |
| 43 | 405 Not Allowed Client Total | Total number of 405 Not Allowed client response. |
| 44 | 406 Not Acceptable Server Total | Total number of 406 Not Acceptable server response. |
| 45 | 406 Not Acceptable Client Total | Total number of 406 Not Acceptable client response. |
| 46 | 407 Proxy Auth Req Server Total | Total number of 407 Proxy Auth Req server response. |
| 47 | 407 Proxy Auth Req Client Total | Total number of 407 Proxy Auth Req client response. |
| 48 | 408 Request Timeout Server Total | Total number of 408 Request Timeout server response. |
| 49 | 408 Request Timeout Client Total | Total number of 408 Request Timeout client response. |
| 50 | 415 Bad Media Type Server Total | Total number of 415 Bad Media Type server response. |
| 51 | 415 Bad Media Type Client Total | Total number of 415 Bad Media Type client response. |
| 52 | 420 Bad Extension Server Total | Total number of 420 Bad Extension server response. |
| 53 | 420 Bad Extension Client Total | Total number of 420 Bad Extension client response. |
| 54 | 421 Extension Reqd Server Total | Total number of 421 Extension Reqd server response. |
| 55 | 421 Extension Reqd Client Total | Total number of 421 Extension Reqd client response. |
| 56 | 422 Too Short Server Total | Total number of 422 Too Short server response. |
| 57 | 422 Too Short Client Total | Total number of 422 Too Short client response. |
| 58 | 423 Too Brief Server Total | Total number of 423 Too Brief server response. |
| 59 | 423 Too Brief Client Total | Total number of 423 Too Brief client response. |
| 60 | 480 Unavailable Server Total | Total number of 480 Unavailable server response. |
| 61 | 480 Unavailable Client Total | Total number of 480 Unavailable client response. |
| 62 | 481 Does Not Exist Server Total | Total number of 481 Does Not Exist server response. |
| 63 | 481 Does Not Exist Client Total | Total number of 481 Does Not Exist client response. |
| 64 | 482 Loop Detected Server Total | Total number of 482 Loop Detected server response. |
| 65 | 482 Loop Detected Client Total | Total number of 482 Loop Detected client response. |
| 66 | 483 Too Many Hops Server Total | Total number of 483 Too Many Hops server response. |
| 67 | 483 Too Many Hops Client Total | Total number of 483 Too Many Hops client response. |
| 68 | 484 Address Incompl Server Total | Total number of 484 Address Incompl server response. |
| 69 | 484 Address Incompl Client Total | Total number of 484 Address Incompl client response. |
| 70 | 485 Ambiguous Server Total | Total number of 485 Ambiguous server response. |
| 71 | 485 Ambiguous Client Total | Total number of 485 Ambiguous client response. |
| 72 | 486 Busy Here Server Total | Total number of 486 Busy Here server response. |
| 73 | 486 Busy Here Client Total | Total number of 486 Busy Here client response. |
| 74 | 486 Busy Here Server Total | Total number of 486 Busy Here server response. |
| 75 | 486 Busy Here Client Total | Total number of 486 Busy Here client response. |
| 76 | 487 Terminated Server Total | Total number of 487 Terminated server response. |
| 77 | 487 Terminated Client Total | Total number of 487 Terminated client response. |
| 78 | 488 Not Acceptable Server Total | Total number of 488 Not Acceptable server response. |
| 79 | 488 Not Acceptable Client Total | Total number of 488 Not Acceptable client response. |
| 80 | 489 Bad Event Server Total | Total number of 489 Bad Event server response. |
| 81 | 489 Bad Event Client Total | Total number of 489 Bad Event client response. |
| 82 | 491 Req Pending Server Total | Total number of 491 Req Pending server response. |
| 83 | 491 Req Pending Client Total | Total number of 491 Req Pending client response. |
| 84 | 4xx Server Total | Total number of 4xx error server response. |
| 85 | 4xx Client Total | Total number of 4xx error client response. |
| 86 | 500 Internal Error Server Total | Total number of 500 Internal Error server response. |
| 87 | 500 Internal Error Client Total | Total number of 500 Internal Error client response. |
| 88 | 501 Not Implemented Server Total | Total number of 501 Not Implemented error server response. |
| 89 | 501 Not Implemented Client Total | Total number of 501 Not Implemented error client response. |
| 90 | 502 Bad Gateway Server Total | Total number of 502 Bad Gateway error server response. |
| 91 | 502 Bad Gateway Client Total | Total number of 502 Bad Gateway error client response. |
| 92 | 503 Service Unavail Server Total | Total number of 503 Service Unavail error server response. |
| 93 | 503 Service Unavail Client Total | Total number of 503 Service Unavail error client response. |
| 94 | 504 Gateway Timeout Server Total | Total number of 504 Gateway Timeout error server response. |
| 95 | 504 Gateway Timeout Client Total | Total number of 504 Gateway Timeout error client response. |
| 97 | 513 Msg Too Large Client Total | Total number of 513 Msg Too Large error client response. |
| 98 | 580 Precon Failure Server Total | Total number of 580 Precon Failure error server response. |
| 99 | 580 Precon Failure Client Total | Total number of 580 Precon Failure error client response. |
| 100 | 5xx Server Total | Total number of 5xx error server response. |
| 101 | 5xx Client Total | Total number of 5xx error client response. |
| 102 | 600 Busy Everywhere Server Total | Total number of 600 Busy Everywhere error server response. |
| 103 | 600 Busy Everywhere Client Total | Total number of 600 Busy Everywhere error client response. |
| 104 | 603 Decline Server Total | Total number of 603 Decline error server response. |
| 105 | 603 Decline Client Total | Total number of 603 Decline error client response. |
| 106 | 604 Not Found Server Total | Total number of 604 Not Found error server response. |
| 107 | 604 Not Found Client Total | Total number of 604 Not Found error client response. |
| 108 | 606 Not Acceptable Server Total | Total number of 606 Not Acceptable error server response. |
| 109 | 606 Not Acceptable Client Total | Total number of 606 Not Acceptable error client response. |
| 110 | 6xx Server Total | Total number of 6xx error server response. |
| 111 | 6xx Client Total | Total number of 6xx error client response. |
| 112 | Response Retrans Server Total | Total number of server Response retransmission requests |
| 113 | Response Retrans Client Total | Total number of client Response retransmission requests |
| 114 | Transaction Timeouts Server Total | Total number of server transaction timeouts. |
| 115 | Transaction Timeouts Client Total | Total number of client transaction timeouts. |
sip-interface-method
This HDR group identifies global counts for listed responses to SIP Methods across a unique SIP Interface. sip-interface-method is this HDR group's configured name.
| 2 | Interface | Name of this SIP Interface. |
sip-agent-method
This HDR group identifies global counts for listed responses to SIP Methods across a unique session agent. sip-agent-method is this HDR group's configured name.
| 2 | Agent | Name of this session agent. |
sip-srvcc
Displays SIP/SRVCC statistics regarding counters of the states of calls handovers. This HDR group corresponds to the show sipd srvcc command and the apSipSRVCCStatsGroup found in ap-sip.mib.
| Position | HDR Column Name | Data Type | Range | Description |
| 1 | Timestamp | Integer | The window of time the HDR collector used to collect the data. The value is in seconds. | |
| 2 | Total Calls | Counter | 0-2147483647 | Total calls subjected to SRVCC |
| 3 | Total Success | Counter | 0-2147483647 | Total successful SRVCC HO |
| 4 | Total Failed | Counter | 0-2147483647 | Total failed SRVCC HO |
| 5 | Total Cancelled | Counter | 0-2147483647 | Total cancelled SRVCC HO |
| 6 | Calls After Answer | Counter | 0-2147483647 | Total calls subjected to SRVCC after answer |
| 7 | After Answer Success | Counter | 0-2147483647 | Total successful SRVCC HO after answer |
| 8 | After Answer Failed | Counter | 0-2147483647 | Total failed SRVCC HO after answer |
| 9 | Calls During Alerting | Counter | 0-2147483647 | Total calls subjected to SRVCC during alerting. |
| 10 | During Alerting Success | Counter | 0-2147483647 | Total successful SRVCC HO during alerting. |
| 11 | During Alerting Failed | Counter | 0-2147483647 | Total failed SRVCC HO during alerting. |
| 12 | ATCF Cancellation | Counter | 0-2147483647 | Total ATCF cancellations |
| 13 | Total Emergency Calls | Counter | 0-2147483647 | Total SRVCC HO for Emergency calls |
| 14 | Emergency Success | Counter | 0-2147483647 | Total successful SRVCC HO for Emergency calls |
| 15 | Emergency Failed | Counter | 0-2147483647 | Total failed SRVCC HO for Emergency calls |
| 16 | EATF Cancellation | Counter | 0-2147483647 | Total EATF Cancellations |
| 17 | Calls During Pre-Alerting | Counter | 0-2147483647 | Total calls subjected to SRVCC during pre-alerting |
| 18 | During Pre-Alerting Success | Counter | 0-2147483647 | Total successful SRVCC HO during pre-alerting |
| 19 | During Per-Alerting Failed | Counter | 0-2147483647 | Total failed SRVCC HO during pre-alerting |
ext-Rx-policy-server
Displays external policy server statistics per configured policy server. This HDR group corresponds to the show policy-server <name> command and the apDiamRxPolicyServerStatsTable found in ap-diameter.mib.
| 2 | Policy Server Name | String | Name of the Rx policy Server | |
| 3 | Sockets | Counter | 0-2147483647 | Total number of sockets created for Rx Policy Server |
| 4 | Connections | Counter | 0-2147483647 | Total number of transport connections created for Rx Policy Server |
| 5 | Client Transactions (CT) | Counter | 0-2147483647 | Total number of client transactions for Rx Policy Server |
| 6 | CT Reserve Requests Sent | Counter | 0-2147483647 | Total number of client transactions reserve requests sent for Rx Policy Server |
| 7 | CT Update Requests Sent | Counter | 0-2147483647 | Total number of client transactions Update requests sent for Rx Policy Server |
| 8 | CT Remove Requests Sent | Counter | 0-2147483647 | Total number of client transactions Remove requests sent for Rx Policy Server |
| 9 | CT Requests Re-Trans | Counter | 0-2147483647 | Total number of re-transmitted request for client transactions for Rx Policy Server |
| 10 | CT Install Resp Received | Counter | 0-2147483647 | Total number of client transactions Install response received for Rx Policy Server |
| 11 | CT Reject Resp Received | Counter | 0-2147483647 | Total number of client transactions Reject response received for Rx Policy Server |
| 12 | CT Remove Resp Received | Counter | 0-2147483647 | Total number of client transactions Remove response received for Rx Policy Server |
| 13 | CT Errors Received | Counter | 0-2147483647 | Total number of client transactions Errors received for Rx Policy Server |
| 14 | CT Transaction Timeouts | Counter | 0-2147483647 | Total number of client transaction timeouts for Rx Policy Server |
| 15 | CT Errors | Counter | 0-2147483647 | Total number of client transaction errors for Rx Policy Server |
| 16 | Server Transactions (ST) | Counter | 0-2147483647 | Total number of server transaction for Rx Policy Server |
| 17 | ST Requests Received | Counter | 0-2147483647 | Total number of request received on server transaction for Rx Policy Server |
| 18 | ST Dup Req Received | Counter | 0-2147483647 | Total number of duplicate request received on server transaction for Rx Policy Server |
| 19 | ST Success Resp Sent | Counter | 0-2147483647 | Total number of success responses sent by server transactions for Rx Policy Server |
| 20 | ST Error Resp Sent | Counter | 0-2147483647 | Total number of error responses sent by server transactions for Rx Policy Server |
| 21 | ST Requests Dropped | Counter | 0-2147483647 | Total number of requests dropped by server transactions for Rx Policy Server |
| 22 | CER Sent | Counter | 0-2147483647 | Total number of CER messages sent by this Rx Policy Server. |
| 23 | CEA Success | Counter | 0-2147483647 | Total number of CEA success messages for this Rx Policy Server. |
| 24 | CEA Errors | Counter | 0-2147483647 | Total number of CEA error messages for this Rx Policy Server. |
| 25 | AAR Sent | Counter | 0-2147483647 | Total number of AAR messages sent by this Rx Policy Server. |
| 26 | AAA Success | Counter | 0-2147483647 | Total number of AAA success messages for this Rx Policy Server. |
| 27 | AAA Errors | Counter | 0-2147483647 | Total number of AAA error messages for this Rx Policy Server. |
| 28 | STR Sent | Counter | 0-2147483647 | Total number of STR messages sent by this Rx Policy Server. |
| 29 | STA Success | Counter | 0-2147483647 | Total number of STA success messages for this Rx Policy Server. |
| 30 | STA Errors | Counter | 0-2147483647 | Total number of STA error messages for this Rx Policy Server. |
| 31 | RAR Rcvd | Counter | 0-2147483647 | Total number of RAR messages sent by this Rx Policy Server. |
| 32 | RAA Rcvd Success | Counter | 0-2147483647 | Total number of RAA success messages for this Rx Policy Server. |
| 33 | RAA Rcvd Errors | Counter | 0-2147483647 | Total number of RAA error messages for this Rx Policy Server. |
| 34 | DWR Sent | Counter | 0-2147483647 | Total number of DWR messages sent by this Rx Policy Server. |
| 35 | DWA Success | Counter | 0-2147483647 | Total number of DWA success messages for this Rx Policy Server. |
| 36 | DWA Errors | Counter | 0-2147483647 | Total number of DWA error messages for this Rx Policy Server. |
| 37 | DWR Rcvd | Counter | 0-2147483647 | Total number of DWR messages received by this Rx Policy Server. |
| 38 | DWA Rcvd Success | Counter | 0-2147483647 | Total number of DWA success messages sent by this Rx Policy Server. |
| 39 | DWA Rcvd Errors | Counter | 0-2147483647 | Total number of DWA error messages sent by this Rx Policy Server. |
| 40 | ASR Rcvd | Counter | 0-2147483647 | Total number of ASR messages sent by this Rx Policy Server. |
| 41 | ASA Rcvd Success | Counter | 0-2147483647 | Total number of ASA success messages for this Rx Policy Server. |
| 42 | ASA Rcvd Errors | Counter | 0-2147483647 | Total number of ASA error messages for this Rx Policy Server. |
sa-ike
Displays IKE Session Agent counters. This HDR group corresponds to the show sa stats ike command and the apSecuritySAIKEStats found in ap-security.mib.
| 2 | ADD-SA Req Rcvd | Counter | 0-2147483647 | Total IKE ADD-SA Requests received |
| 3 | ADD-SA Success Resp Sent | Counter | 0-2147483647 | Total IKE ADD-SA success response sent |
| 4 | ADD-SA Fail Resp Sent | Counter | 0-2147483647 | Total IKE ADD-SA fail response sent |
| 5 | DEL-SA Req Rcvd | Counter | 0-2147483647 | Total IKE DEL-SA Requests received. |
| 6 | DEL-SA Success Resp Sent | Counter | 0-2147483647 | Total IKE DEL-SA Success response sent |
| 7 | DEL-SA Fail Resp Sent | Counter | 0-2147483647 | Total IKE DEL-SA Fail response sent. |
| 8 | ACQUIRE-SA Req Sent | Counter | 0-2147483647 | Total IKE ACQUIRE-SA Requests sent. |
| 9 | ACQUIRE-SA Success Resp Rcvd | Counter | 0-2147483647 | Total IKE ACQUIRE -SA Success response received. |
| 10 | ACQUIRE-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total IKE ACQUIRE -SA Fail response received. |
| 11 | ACQUIRE-SA Trans Timeouts | Counter | 0-2147483647 | Total IKE ACQUIRE -SA Transaction timeouts. |
| 12 | SA Added | Counter | 0-2147483647 | Total number of SA Added. |
| 13 | SA Add Failed | Counter | 0-2147483647 | Total number of SA Add Failed |
| 14 | SA Deleted | Counter | 0-2147483647 | Total number of SA Deleted. |
| 15 | SA Delete Failed | Counter | 0-2147483647 | Total number of SA Delete failed. |
sa-imsaka
Displays IMS-AKA Session Agent counters. This HDR group corresponds to the show sa stats ims-aka all command and the apSipSRVCCStatsobjects found in ap-sip.mib.
| 1 | TimeStamp | Integer | The window of time the HDR collector used to collect the data. The value is in seconds. | |
| 2 | ADD-SA Req Sent | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Requests sent |
| 3 | ADD-SA Req Rcvd | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Requests received |
| 4 | ADD-SA Success Resp Sent | Counter | 0-2147483647 | Total IMS-AKA ADD-SA success response sent |
| 5 | ADD-SA Success Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA ADD-SA success response received |
| 6 | ADD-SA Fail Resp Sent | Counter | 0-2147483647 | Total IMS-AKA ADD-SA fail response sent |
| 7 | ADD-SA Fail Invalid Param Sent | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Fail Message sent due to invalid parameter. |
| 8 | ADD-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA ADD-SA fail response received |
| 9 | ADD-SA Fail Addr Mask Mismatch | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Fail Message sent due to Address Mask Mismatch. |
| 10 | ADD-SA Fail Inv Proto Params | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Fail Message sent due to invalid Protocol parameters. |
| 11 | ADD-SA Fail Inv Proto Data | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Fail Message sent due to invalid Protocol data. |
| 12 | ADD-SA Trans Timeouts | Counter | 0-2147483647 | Total IMS-AKA ADD-SA Transaction timeouts. |
| 13 | DEL-SA Req Sent | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Requests sent |
| 14 | DEL-SA Req Rcvd | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Requests received. |
| 15 | DEL-SA Success Resp Sent | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Success response sent |
| 16 | DEL-SA Success Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Success response received. |
| 17 | DEL-SA Fail Resp Sent | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Fail Response sent. |
| 18 | DEL-SA Fail Invalid Param Sent | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Fail Message sent due to invalid parameter |
| 19 | DEL-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Fail responses received. |
| 20 | DEL-SA Trans Timeouts | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Messages resulting from Transaction timeouts |
| 21 | DEL-SA Due to Timeout | Counter | 0-2147483647 | Total IMS-AKA DEL-SA Messages resulting from timeouts. |
| 22 | MOD-SA Req Sent | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Requests sent |
| 23 | MOD-SA Req Rcvd | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Requests received. |
| 24 | MOD-SA Success Resp Sent | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Success response sent |
| 25 | MOD-SA Success Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Success response received. |
| 26 | MOD-SA Fail Resp Sent | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Fail Response sent. |
| 27 | MOD-SA Fail Invalid Param Sent | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Fail Message sent due to invalid parameter |
| 28 | MOD-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Fail responses received. |
| 29 | MOD-SA Trans Timeouts | Counter | 0-2147483647 | Total IMS-AKA MOD-SA Messages resulting from Transaction timeouts |
| 30 | SA Added | Counter | 0-2147483647 | Total number of SA Added. |
| 31 | SA Added Inbound | Counter | 0-2147483647 | Total IMS-AKA SA added in inbound. |
| 32 | SA Added Outbound | Counter | 0-2147483647 | Total IMS-AKA SA added in outbound. |
| 33 | SA Add Failed | Counter | 0-2147483647 | Total SA addition failed. |
| 34 | SA Add Inbound PPM Failed | Counter | 0-2147483647 | Total SA Add Inbound PPM Failed |
| 35 | SA Add Outbound PPM Failed | Counter | 0-2147483647 | Total SA Add Outbound PPM Failed |
| 36 | SA Deleted | Counter | 0-2147483647 | Total number of SA deleted. |
| 37 | SA Deleted Inbound | Counter | 0-2147483647 | Total number of SA deleted in the inbound. |
| 38 | SA Deleted Outbound | Counter | 0-2147483647 | Total number of SA deleted in the outbound. |
| 39 | SA Delete Failed | Counter | 0-2147483647 | Total number of SA delete failed. |
| 40 | SA Delete Inbound PPM Failed | Counter | 0-2147483647 | Total number of SA Delete Inbound PPM Failed |
| 41 | SA Delete Outbound PPM Failed | Counter | 0-2147483647 | Total number of SA Delete Outbound PPM Failed |
| 42 | SA Del Fail Addr Mask Mismatch | Counter | 0-2147483647 | Total number of SA Delete Failed due to Addr Mask Mismatch |
| 43 | SA Del Fail Inv Proto Params | Counter | 0-2147483647 | Total number of SA Delete Failed due to Invalid Protocol Parameters. |
| 44 | SA Del Fail Inv Proto Data | Counter | 0-2147483647 | Total number of SA Delete Failed due to invalid Protocol Data. |
| 45 | SA Collision | Counter | 0-2147483647 | Total number of SA collisions. |
| 46 | SA CollisionRecoveryFail | Counter | 0-2147483647 | Total number of SA collision recovery failed |
| 47 | SA CollisionRecoverySucc | Counter | 0-2147483647 | Total number of SA collision recovery successful |
| 48 | SA CollisionRecoveryLkupFail | Counter | 0-2147483647 | Total number of SA collisions recovery lookup failed. |
| 49 | SA Key Not Found | Counter | 0-2147483647 | Total number of SA Key not Found event. |
| 50 | SA Key Not Found Timeout | Counter | 0-2147483647 | Total number of SA Key not Found timeout event. |
| 51 | SA Key Exists | Counter | 0-2147483647 | Total number of SA Key exists event. |
| 52 | SA Recovery | Counter | 0-2147483647 | Total number of SA recovery event. |
| 53 | SA Recovery Fail | Counter | 0-2147483647 | Total number of SA recovery fail event. |
| 54 | SA Trans Queue | Counter | 0-2147483647 | Total count of SA Trans Queue. |
| 55 | SA Red Queue | Counter | 0-2147483647 | Total count of SA Redundancy Queue. |
| 56 | SA inbound record(SATable) | Counter | 0-2147483647 | Total count of SA inbound record (SA Table) |
| 57 | SA outbound record(SATable) | Counter | 0-2147483647 | Total count of SA outbound record (SA Table) |
| 58 | SA invalid timer | Counter | 0-2147483647 | Total number of times SA Invalid timer event occurred. |
| 59 | SA add fail in table | Counter | 0-2147483647 | Total number of times SA Add fail in table. |
| 60 | SA send ADD to Red | Counter | 0-2147483647 | Total number of times SA sent ADD event to redundant peer. |
| 61 | SA send MOD to Red | Counter | 0-2147483647 | Total number of times SA sent modify event to redundant peer. |
| 62 | SA Rcvd ADD from Active | Counter | 0-2147483647 | Total number of times SA received ADD event from Active |
| 63 | SA Rcvd MOD from Active | Counter | 0-2147483647 | Total number of times SA received MODIFY event from Active |
| 64 | SA Add Red Queue Failed | Counter | 0-2147483647 | Total number of SA Add to Redundancy Queue failed event. |
| 65 | Invalid Red Action | Counter | 0-2147483647 | Total number of Invalid Redundant action |
| 66 | Send Timed Del To Red | Counter | 0-2147483647 | Total number of times Timed Del sent to redundant pair. |
| 67 | Rcvd Timed Del Frm Act | Counter | 0-2147483647 | Total number of times Timed Del from Active received. |
| 68 | SA request transaction queue size | integer | SA request transaction queue size of the security association agent | |
| 69 | Allow transaction quota | integer | Allowed transaction quota of the security association agent | |
| 70 | Delay delete count | integer | Delay delete count of the security association agent | |
| 71 | max trans queue size | integer | Maximum transaction queue size of the security association agent | |
| 72 | Total Regmsg | Counter | 0-2147483647 | Total number of registration messages received. |
| 73 | Unprotect Msg | Counter | 0-2147483647 | Total number of unprotected registration messages received. |
| 74 | Unprotect Msg Before Expiry | Counter | 0-2147483647 | Total number of unprotected registration messages received before expiry. |
| 75 | Inbound Prior Disconnects | Counter | 0-2147483647 | Total number of prior disconnects on the inbound. |
| 76 | Outbound Prior Disconnects | Counter | 0-2147483647 | Total number of prior disconnects on the outbound. |
| 77 | Answer Before Challenge | Counter | 0-2147483647 | Total number of registration answer messages received before challenge. |
| 78 | Protect Msg | Counter | 0-2147483647 | Total number of protected registration messages received. |
| 79 | Initial Reg Rej too busy | Counter | 0-2147483647 | Total number of initial registration messages rejected with busy error code. |
| 80 | Initial Reg Rej no resource | Counter | 0-2147483647 | Total number of initial registration messages rejected because of resource unavailability. |
| 81 | Initial Reg Fail alloc mem | Counter | 0-2147483647 | Total number of initial registration messages rejected because of memory allocation failure. |
| 82 | Initial Reg Ims entry exist | Counter | 0-2147483647 | Total number of initial registration messages for which IMS entry already exists. |
| 83 | Initial Reg Bad sec hdr | Counter | 0-2147483647 | Total number of initial registration messages received with bad security header. |
| 84 | Initial Reg Passed quota | Counter | 0-2147483647 | Total number of initial registration messages that passed the quota. |
| 85 | Re-Reg Rej too busy | Counter | 0-2147483647 | Total number of re-registration messages rejected with busy error code. |
| 86 | Re-Reg Rej no resource | Counter | 0-2147483647 | Total number of re-registration messages rejected because of resource unavailability. |
| 87 | Re-Reg Bad sec hdr | Counter | 0-2147483647 | Total number of re-registration messages received with bad security header. |
| 88 | Re-Reg No ims entry | Counter | 0-2147483647 | Total number of re-registration messages for which no IMS entry exists. |
| 89 | Re-Reg Passed quota | Counter | 0-2147483647 | Total number of re-registration messages that passed the quota. |
| 90 | Re-Reg Fwd unpro Reg | Counter | 0-2147483647 | Total number of unprotected re-registration messages that were forwarded. |
| 91 | Re-Reg Reuse spi false | Counter | 0-2147483647 | Total number of re-registration messages for which re-use SPI is false. |
| 92 | Re-Reg Reuse spi true | Counter | 0-2147483647 | Total number of re-registration messages for which re-use SPI is true. |
| 93 | Re-Reg Incomplete reg | Counter | 0-2147483647 | Total number of re-registration messages resulting in incomplete registration. |
sa-srtp
Displays SRTP Session Agent counters. This HDR group corresponds to the show sa stats srtp command and the apSecuritySASRTPStats found in ap-security.mib.
| 2 | ADD-SA Req Sent | Counter | 0-2147483647 | Total SRTP ADD-SA Requests sent |
| 3 | ADD-SA Req Rcvd | Counter | 0-2147483647 | Total SRTP ADD-SA Requests received |
| 4 | ADD-SA Success Resp Sent | Counter | 0-2147483647 | Total SRTP ADD-SA success response sent |
| 5 | ADD-SA Success Resp Rcvd | Counter | 0-2147483647 | Total SRTP ADD-SA success response received |
| 6 | ADD-SA Fail Resp Sent | Counter | 0-2147483647 | Total SRTP ADD-SA fail response sent |
| 7 | ADD-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total SRTP ADD-SA Fail response received. |
| 8 | ADD-SA Trans Timeouts | Counter | 0-2147483647 | Total SRTP ADD-SA Transaction timeouts. |
| 9 | DEL-SA Req Sent | Counter | 0-2147483647 | Total SRTP DEL-SA Requests sent |
| 10 | DEL-SA Req Rcvd | Counter | 0-2147483647 | Total SRTP DEL-SA Requests received. |
| 11 | DEL-SA Success Resp Sent | Counter | 0-2147483647 | Total SRTP DEL-SA Success response sent |
| 12 | DEL-SA Success Resp Rcvd | Counter | 0-2147483647 | Total SRTP DEL-SA Success response received. |
| 13 | DEL-SA Fail Resp Sent | Counter | 0-2147483647 | Total SRTP DEL-SA Fail Response sent. |
| 14 | DEL-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total SRTP DEL-SA Fail response received. |
| 15 | DEL-SA Trans Timeouts | Counter | 0-2147483647 | Total SRTP DEL-SA Transaction timeouts. |
| 16 | MOD-SA Req Sent | Counter | 0-2147483647 | Total SRTP MOD-SA Requests sent |
| 17 | MOD-SA Req Rcvd | Counter | 0-2147483647 | Total SRTP MOD-SA Requests received. |
| 18 | MOD-SA Success Resp Sent | Counter | 0-2147483647 | Total SRTP MOD-SA Success response sent |
| 19 | MOD-SA Success Resp Rcvd | Counter | 0-2147483647 | Total SRTP MOD-SA Success response received. |
| 20 | MOD-SA Fail Resp Sent | Counter | 0-2147483647 | Total SRTP MOD-SA Fail Response sent. |
| 21 | MOD-SA Fail Resp Rcvd | Counter | 0-2147483647 | Total SRTP MOD-SA Fail response received. |
| 22 | MOD-SA Trans Timeouts | Counter | 0-2147483647 | Total SRTP MOD-SA transaction timeouts. |
| 23 | SA Added | Counter | 0-2147483647 | Total SRTP SA Added |
| 24 | SA Add Failed | Counter | 0-2147483647 | Total SRTP SA Add failed. |
| 25 | SA Deleted | Counter | 0-2147483647 | Total SRTP SA deleted. |
| 26 | SA Delete Failed | Counter | 0-2147483647 | Total SRTP SA delete failed. |
| 27 | SA Collision | Counter | 0-2147483647 | Total SRTP SA collision |
| 28 | SA Key Not Found | Counter | 0-2147483647 | Total SRTP SA Key not found event. |
sip-codec-per-realm
Captures codec usage on a per-realm basis. This HDR group corresponds to the show sipd codecs <realm_id> command and the apCodecRealmStatsTable found in ap-codec.mib.
| 2 | Realm Name | String | Name of the Realm | |
| 3 | Transcoded | Counter | 0-2147483647 | Lifetime total of all sessions for which transcoding between two or more codecs was applied. |
| 4 | Transrated | Counter | 0-2147483647 | Lifetime total of all sessions for which the packetization interval among dialogs in the session was changed. |
| 5 | Transparent | Counter | 0-2147483647 | Lifetime total of all sessions for which no transcoding was applied. |
| 6 | PCMU Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to PCMU codec. |
| 7 | PCMA Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to PCMA codec. |
| 8 | G722 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G722 codec. |
| 9 | G723 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G723 codec. |
| 10 | G726-16 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G726-16 codec. |
| 11 | G726-24 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G726-24 codec. |
| 12 | G726-32 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G726-32 codec. |
| 13 | G726-40 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G726-40 codec. |
| 14 | G728 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G728 codec. |
| 15 | G729 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to G729 codec. |
| 16 | GSM Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to GSM codec. |
| 17 | iLBC Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to iLBC codec. |
| 18 | H261 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to H261 codec. |
| 19 | H263 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to H263 codec. |
| 20 | T38 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to T38 codec. |
| 21 | AMR Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to AMR codec. |
| 22 | AMR-WB Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to AMR-WB codec. |
| 23 | EVRC Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRC codec. |
| 24 | EVRC0 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRC0 codec. |
| 25 | EVRC1 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRC1 codec. |
| 26 | EVRCB Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRCB codec. |
| 27 | EVRCB0 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRCB0 codec. |
| 28 | EVRCB1 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVRCB1 codec. |
| 29 | opus Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to opus codec. |
| 30 | SILK Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to SILK codec. |
| 31 | T140 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to T140 codec. |
| 32 | BAUDOT Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to BAUDOT codec. |
| 33 | H264 Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to H264 codec. |
| 34 | EVS Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to EVS codec. |
| 35 | Other Count | Counter | 0-2147483647 | Lifetime total of all SDP media streams received in the realm which negotiated to Other (Unknown) codec. |
xcode-codec-util
Displays licensed codecs, the total provisioned capacity, and the current number of sessions in use. This HDR group corresponds to the show xcode load command and apLicenseEntry found in ap-license.mib and apCodecTranscodingResourceUtilMIBObjects found in ap-codec.mib.
| 2 | Licensed Codec Name | String | Name of the licensed Codec | |
| 3 | Sessions | Gauge | 0-2147483647 | Total number of active transcoded session for this codec. |
| 4 | Capacity | Integer | Total licensed capacity of the codec. If the licensed capacity is uncapped, a zero is displayed. |
xcode-session-gen-info
Displays general counters about transcoding sessions. This HDR group corresponds to the show xcode load command and the apCodecTranscodingTCULoadStatsTable found in ap-codec.mib.
| 2 | Total Transcoded Sessions | Gauge | 0 - 2^63-1 | Total number of active transcoded sessions in the system. |
| 3 | DSP MIPS Protection | String | Indication whether DSP MIPS Protection is active or not. |
xcode-tcm-util
Displays transcoding resources load statistics. This HDR group corresponds to the show xcode load command and the apCodecTranscodingTCULoadStatsTable found in ap-codec.mib.
| 2 | TCU Num | Integer | Transcoding Unit Number | |
| 3 | TCM Num | Integer | Transcoding Module for the particular TCU | |
| 4 | DSP Num | Integer | DSP Number for the particular TCM | |
| 5 | Session Count | Gauge | 0-2147483647 | The number of active sessions for a DSP |
| 6 | Current Load | Gauge | 0.00% to 100.00% | The current load (in percentage) for a DSP. The precision of the value will be maintained up to two places of decimal as in acli. |
| 7 | Peak Load | Counter | 0.00% to 100.00% | The peak lifetime load (in percentage) for a DSP. The precision of the value will be maintained up to two places of decimal as in acli. |
| 8 | DSP Overloaded | String | Indication whether the DSP is overloaded or not |
