Sip-invite Format of HDR Data in CSV File
The HDR data for the sip-invite group displays on multiple lines in the CSV file. The first HDR record displays the list of statistics in column format. The second HDR record also displays statistics in column format, and so on. Both client and server totals are included in the data.
The following shows an example of the sip-invite group CSV file for a client and a server displayed in a Microsoft DOS window format.
C:\AcmePacket> type 130204198.csv Timestamp,Message/Event,Server Totals,Client Totals 1301702288,INVITE Requests ,0,0 1301702288,Retransmission,0,0 1301702288,100 Trying,0,0 1301702288,180 Ringing,0,0 1301702288,181 Forwarded,0,0 1301702288,183 Progress,0,0 1301702288,1xx Provisional,0,0 1301702288,200 OK,0,0 1301702288,202 Accepted,0,0 1301702288,2xx Success,0,0 1301702288,30x Moved,0,0 .,,, .,,, .,,, 1301702288,Transaction Timeouts,,0 1301702288,Locally Throttled,,0 1301702348,INVITE Requests ,0,0 1301702348,Retransmission,0,0 1301702348,100 Trying,0,0 1301702348,180 Ringing,0,0 1301702348,181 Forwarded,0,0 1301702348,183 Progress,0,0 1301702348,1xx Provisonal,0,0 1301702348,200 OK,0,0 1301702348,202 Accepted,0,0 1301702348,2xx Success,0,0 1301702348,30x Moved,0,0 .,,, .,,, .,,, 1301702348,Response Retrans,0,0 1301702348,Transaction Timeouts,,0 1301702348,Locally Throttled,,0
The following shows an example of the sip-invite group CSV file for a client and a server displayed in a Microsoft rendering application format.
Timestamp Message/Event Server Totals Client Totals 1301702288 INVITE Requests 0 0 1301702288 Retransmission 0 0 1301702288 100 Trying 0 0 1301702288 180 Ringing 0 0 1301702288 181 Forwarded 0 0 1301702288 183 Progress 0 0 1301702288 1xx Provisional 0 0 1301702288 200 OK 0 0 1301702288 202 Accepted 0 0 1301702288 2xx Success 0 0 1301702288 30x Moved 0 0
