Configuration Overview
Oracle Communications Session Delivery Product Virtual Machine (VM) deployments require configuration of the VM environment and, separately, configuration of the OC-SDP itself. VM-specific configuration on the OC-SDP includes boot parameter configuration, enabling functionality and performance tuning.
During VM installation, you can configure operational information within the system's boot parameters, including:
- IP address
 - Host name
Refer to the instructions on installing the OC-SDP on each supported hypervisor to see how and when you do this during installation. Refer to the ACLI Configuration Guide for instruction on changing these settings after installation.
During VM installation, the OC-SDP sets default functionality, assigning cores to signaling and media forwarding. If you need DoS and/or transcoding functionality, configure the applicable cores after installation and before performing service. See the ACLI Configuration Guide for core configuration instructions.
Applicable performance tuning configuration after deployment includes:
- Media manager traffic/bandwidth utilization tuning
 - Datapath-related CPU core allocation
See the ACLI Configuration Guide for instructions on VM tuning configuration.
For Xen-based hypervisors, the default boot mode uses DHCP to obtain an IP address for the first management interface (wancom0) unless a static IP is provisioned. Note that DHCP on wancom0 does not support lease expiry, so the hypervisor must provide persistent IP address mapping. If persistent IP address mapping is not provided, the user must manually restart the VM whenever the wancom0 IP address changes due to a manual change or DHCP lease expiry.Beyond installation, VM-related functional support, and VM-related tuning, you perform basic OC-SDP configuration procedures after installation, including:
- Setting Passwords
 - Setup Product
 - Setup Entitlements
 - Service configuration
Refer to the ACLI Configuration Guide for instructions on these procedures.
Refer to the documentation listed in the About This Guide section of this document for other OC-SDP-related configuration.
