SNMP Object
The following table describes the standard SNMP Get support for the SNMP group which is a collection of objects providing basic instrumentation and control of an SNMP entity.
| MIB Object | Object ID: 1.3.6.1.2.1.11 + | Description |
| snmpInPkts | .1 | Total number of messages delivered to the SNMP entity from the transport service. |
| snmpInBadVersions | .3 | Total number of SNMP messages delivered to the SNMP entity for an unsupported SNMP version. |
| snmpInBadCommunityNames | .4 | Total number of SNMP messages delivered to the SNMP entity which used a SNMP community name not known to said entity. |
| snmpInBadCommunityUses | .5 | Total number of SNMP messages delivered to the SNMP entity which represented an SNMP operation which was not allowed by the SNMP community named in the message. |
| snmpInASNParseErrs | .6 | Total number of ASN.1 or BER errors encountered by the SNMP entity when decoding received SNMP messages. |
| snmpEnableAuthenTraps | .30 | Indicates whether the SNMP entity is permitted to generate authenticationFailure traps. The value of this object overrides any configuration information; as such, it provides a means whereby all authenticationFailure traps may be disabled. (It is strongly recommended that this object be stored in non-volatile memory so that it remains constant across re-initializations of the network management system.) |
| snmpSilentDrops | .31 | Total number of GetRequest-PDUs, GetNextRequest-PDUs, GetBulkRequest-PDUs, SetRequest-PDUs, and InformRequest-PDUs delivered to the SNMP entity which were silently dropped because the size of a reply containing an alternate Response-PDU with an empty variable-bindings field was greater than either a local constraint or the maximum message size associated with the originator of the request. |
| snmpProxyDrops | .32 | Total number of GetRequest-PDUs, GetNextRequest-PDUs, GetBulkRequest-PDUs, SetRequest-PDUs, and InformRequest-PDUs delivered to the SNMP entity which were silently dropped because the transmission of the (possibly translated) message to a proxy target failed in a manner (other than a timeout) such that no Response-PDU could be returned. |
