apSecurity Traps (ap-security.mib)
The
		following traps are found in
		ap-security.mib.
| Trap | Description |
| apSecurityTunnelFailureNotification: 1.3.6.1.4.1.9148.3.9.3.1.0.1 | Generated when an IPSec IKEV2 tunnel cannot be established. |
| apSecurityTunnelDPDNotification: 1.3.6.1.4.1.9148.3.9.3.2.0.1 | Generated when an IPSec IKEV2 tunnel fails because of Dead Peer Detection (DPD). |
| apSecurityCRLInvalidNotification: 1.3.6.1.4.1.9148.3.9.3.4.0.1 | Generated when an invalid CRL is detected. |
| apSecurityCertExpiredNotification 1.3.6.1.4.1.9148.3.9.3.6.0.1 | This trap is generated periodically if a locally installed certificate has expired. The interval of minutes between this trap being generated is configured in the local-cert-exp-trap-int parameter. |
| apSecurityCertExpireSoonNotification 1.3.6.1.4.1.9148.3.9.3.6.0.2 | This trap is generated if a locally installed certificate will soon expire. The number of days before expiration in which this trap is sent is configured in the local-cert-exp-warn-period parameter. |
| apSecurityTacacsFailureNotification 1.3.6.1.4.1.9148.3.9.3.1.0.4 | Generated when TACACS+
					 authentication request fails due to one of the following reasons:
| apSecurityTscfCap 1.3.6.1.4.1.9148.2.1.14.19 | Acme Packet Agent Capability for enterprise TSCF Security MIB. |
| apSecurityTscfStatsGroup 1.3.6.1.4.1.9148.3.9.4.2.13 | Collection of MIB objects for the collection of TSCF statistics |
| apSecurityTscfNotificationsGroup 1.3.6.1.4.1.9148.3.9.4.3.11 | Collection of notifications for TSCF resource alerts |
| apSecurityTscfAddressPoolUsageTrap 1.3.6.1.4.1.9148.3.9.3.8.0.1 / apSecurityTscfAddressPoolUsageClearTrap 1.3.6.1.4.1.9148.3.9.3.8.0.2 | These notifications are sent when the available IP addresses in TSCF address pool depletes below the configured threshold level, then increases above the configured threshold level. The configuration MIB objects involved are: apSecurityTscfAddressPoolName (1.3.6.1.4.1.9148.3.9.1.15.1.1) and apSecurityTscfAddrPoolThresholdLevel (1.3.6.1.4.1.9148.3.9.2.29). The statistical MIB objects involved are: apSecurityTscfInUseAddressCount (1.3.6.1.4.1.9148.3.9.1.15.1.3) and apSecurityTscfTotalAddressCount (1.3.6.1.4.1.9148.3.9.1.15.1.2). |
| apSecurityTscfMaxTunnelTrap 1.3.6.1.4.1.9148.3.9.3.8.0.3 / apSecurityTscfClearMaxTunnelTrap 1.3.6.1.4.1.9148.3.9.3.8.0.4 | These notifications are sent when
					 the number of TSCF tunnels established exceeds the number of TSCF tunnels
					 licensed, or exceeds the configured threshold for the maximum numbered of
					 tunnels, then decreases below the threshold. The configuration MIB objects involved are: apTscfLicenseTunnelCount (1.3.6.1.4.1.9148.3.9.1.14.82) and apSecurityTscfMaxTunnelsThresholdLevel (1.3.6.1.4.1.9148.3.9.2.30). The statistical MIB object involved is: apTscfActiveTunnels (1.3.6.1.4.1.9148.3.9.1.14.1). |
