apDiameter Traps (ap-diameter.mib)
The following traps
		are found in
		ap-diameter.mib.
| Trap | Description |
| apDiameterAcctSrvrUpTrap: .1.3.6.1.4.1.9148.3.13.1.2.2.0.1 | Generated when a Diameter Accounting Server goes up. |
| apDiameterAcctSrvrDownTrap: 1.3.6.1.4.1.9148.3.13.1.2.2.0.2 | Generated when a Diameter Accounting Server goes down. |
| apAcctMsgQueueFullTrap: 1.3.6.1.4.1.9148.3.13.1.2.2.0.3 | Generated when the accounting message queue is full and all accounting servers are down. |
| apAcctMsgQueueFullClearTrap: 1.3.6.1.4.1.9148.3.13.1.2.2.0.4 | Generated when the apAcctMsgQueueFullTrap condition clears. |
| apDiameterSrvrErrorResultTrap: 1.3.6.1.4.1.9148.3.13.1.2.2.0.5 | Generated when the Diameter Server returns 3xxx (Protocol Errors), 4xxx (Transient Failures), or 5xxx (Permanent Failure) Result-Code AVP (268). |
| apDiameterSrvrSuccessResultTrap: 1.3.6.1.4.1.9148.3.13.1.2.2.0.6 | After an error result, generated when the Diameter Server returns a 2xxx (Success) Result-Code AVP (268). |
