apUSBC Traps (ap-usbcsys.mib)
 The following traps are found in
		ap-usbcsys.mib.
| Trap Name | Description |
| apUsbcSysThreadUsageExceededTrap 1.3.6.1.4.1.9148.3.17.2.2.1.1 | The trap is generated when a thread is exceeding pre-defined usage. |
| apUsbcSysThreadUsageClearTrap 1.3.6.1.4.1.9148.3.17.2.2.1.2 | The trap is generated when a thread is dropping back under pre-defined usage. |
| apUsbcSysThreadUsageOverloadEnableTrap 1.3.6.1.4.1.9148.3.17.2.2.1.3 | The trap is generated when a thread cpu overload is activated. |
| apUsbcSysThreadUsageOverloadDisableTrap 1.3.6.1.4.1.9148.3.17.2.2.1.4 | The trap is generated when a thread cpu overload is de-activated. |
| apUsbcSysThreadNotRespondingTrap 1.3.6.1.4.1.9148.3.17.2.2.1.0.7 | The trap is generated when a thread is not responding. |
| apMutexDeadLockDetectedTrap 1.3.6.1.4.1.9148.3.17.2.2.1.0.5 | The trap is generated when the system detects a deadlock. |
| apMutexDeadLockClearTrap 1.3.6.1.4.1.9148.3.17.2.2.1.0.6 | The trap is generated when the system detects that a deadlock us clear. |
