Acme Packet License MIB (ap-license.mib)
The following table describes the SNMP GET query names for the License MIB (ap-license.mib). The apLicenseEntry object has the OID 1.3.6.1.4.1.9148.3.5.1.1.1.
| SNMP GET Query Name | Object ID: 1.3.6.1.4.1.9148.3.5.1.1.1 + | Description |
| apLicenseKey | .2 | Key, not applicable to the first index, which represents the consolidated license. Displays N/A. |
| apLicenseCapacity | .3 | Maximum number of simultaneous sessions allowed by a system for all combined protocols. |
| apInstallDate | .4 | Installation time and date in the following format: hh:mm:ss Month Day Year. Displays N/A if a license is not enabled. |
| apLicenseBeginDate | .5 | Installation time and date in the following format: hh:mm:ss month day year. Displays N/A if a license is not enabled. |
| apLicenseExpireDate | .6 | Expiration time and date in the following format: hh:mm:ss Month Day Year. Displays N/A if a license is not enabled. |
| apLicenseSIPFeature | .7 | Value that indicates whether a Session Initiation Protocol (SIP) license is present. A value of 1 indicates that SIP licensing is enabled. A value of 2 indicates that SIP licensing is not enabled. |
| apLicenseMGCPFeature | .8 | Not Supported. |
| apLicenseH323Feature | .9 | Value that indicates whether a H.323 Protocol license is present. A value of 1 indicates that H.323 licensing is enabled. A value of 2 indicates that H.323 licensing is not enabled. |
| apLicenseIWFFeature | .10 | Value that indicates whether a Interworking Feature (IWF) license is present. A value of 1 indicates that IWF licensing is enabled. A value of 2 indicates that IWF licensing is not enabled. |
| apLicenseQOSFeature | .11 | Value that indicates whether a Quality of Service (QoS) license is present. A value of 1 indicates that QoS licensing is enabled. A value of 2 indicates that QoS licensing is not enabled. |
| apLicenseACPFeature | .12 | Value that indicates whether a Acme Control Protocol (ACP) license is present. A value of 1 indicates that ACP licensing is enabled. A value of 2 indicates that ACP licensing is not enabled. |
| apLicenseLPFeature | .13 | Value that indicates whether a Local Policy (LP) license is present. A value of 1 indicates that LP licensing is enabled. A value of 2 indicates that LP licensing is not enabled. |
| apLicenseSAGFeature | .14 | Value that indicates whether a Session Agent Group (SAG) license is present. A value of 1 indicates that SAG licensing is enabled. A value of 2 indicates that SAG licensing is not enabled. (load balancing feature) |
| apLicenseACCTFeature | .15 | Value that indicates whether a ACCT license is present. An ACCT license allows the system to create connections and send CDRs to one or more RADIUS servers. A value of 1 indicates that ACCT licensing is enabled. A value of 2 indicates that ACCT licensing is not enabled. |
| apLicenseHAFeature | .16 | Value that indicates whether a High Availability (HA) license is present. A value of 1 indicates that HA licensing is enabled. A value of 2 indicates that HA licensing is not enabled. |
| apLicensePACFeature | .17 | Value that indicates whether a PAC license is present. A value of 1 indicates that PAC licensing is enabled. A value of 2 indicates that PAC licensing is not enabled. |
| apLicenseIKEFeature | .18 | |
| apLicenseIPsecTunCap | .19 | IPsec Tunnel Capacity |
| apLicenseAuthFeature | .20 | |
| apLicenseDatabaseRegFeature | .21 | |
| apLicenseDatabaseRegCap | .22 | Database registration contact capacity |
| apLicenseSLBEndpointCap | .23 | SLB endpoint capacity |
| apLicenseAMRLicensedCap | .24 | AMR codec licensed capacity |
| apLicenseAMRWBLicensedCap | .25 | AMR-WB codec licensed capacity |
| apLicenseEVRCLicensedCap | .26 | EVRC codec licensed capacity |
| apLicenseEVRCBLicensedCap | .27 | EVRCB codec licensed capacity |
| apLicenseOPUSLicensedCap | .28 | OPUS codec licensed capacity |
| apLicenseSILKLicensedCap | .29 | SILK codec licensed capacity |
| apLicenseEVSLicensedCap | .30 | EVS codec licensed capacity |
