Basic SNMP Parameters
The Oracle Communications Session Border Controller (OCSBC) includes several parameters that control basic SNMP functionality and are common to both SNMPv1v2 and SNMPv3 deployments. The MIB-related elements are for informational purposes, and are helpful if set. The remainder of the parameters determine if certain OCSBC events are reported to the SNMP system.
System-wide configurations including:
- Enable SNMP operation (enabled by default)
- System-related contact information
- Enable the
OCSBC to send
information within traps, including:
- syslog
- authentication
- environmental
- system monitoring
