Standard Traps
The following table identifies the standard traps that the system supports.
| Trap Name | Description |
| linkUp | The SNMPv2 agent detects that the ifOperStatus object of an interface has transferred from the down state to the up state. The ifOperStatus value indicates the other state. |
| linkDown | The SNMPv2 agent detects that the ifOperStatus object of an interface has transferred from the up state to the down state. The ifOperStatus value indicates the other state. |
| coldStart | The SNMPv2 agent is reinitializing itself and
				  its configuration may have been altered. This trap is not associated with a system alarm. |
| authenticationFailure | The SNMPv2 agent received a protocol message
				  that was not properly authenticated. If the snmp-enabled and
				  enable-snmp-auth-traps fields in the ACLI's system-config element are set to
				  enabled a snmpEnableAuthenTraps object is generated. This trap is not associated with a system alarm. |
