Specify SNMPv3 View Access to a MIB
 Access the
			 system configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)#
 Type
			 snmp-view-entry and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters used to include or exclude view access.
ORACLE(system)# snmp-view-entry ORACLE(snmp-view-entry)#
				name Specify the SNMPv3 view name.
Valid value:- <SNMP-view-name-string>—that is 1 to 24 characters.
included-list— Use
			 this parameter to include view access to a MIB OID subtree or multiple OID
			 subtrees for this SNMPv3 view name.
Valid value:- <OID(s)>—Object Identifier number separated by a dot (.), in which each subsequent number is a sub-identifier. You can enter multiple OIDs by separating them with a space. Each subtree OID starts with the prefix 1.3.6.1. For example, 1.3.6.1.4.
- Repeat the previous step if you need to include or exclude additional views.
excluded-list—Use
			 this parameter to exclude view access to a MIB OID node for this SNMPv3 view
			 name.
Valid value:- <OID(s)>— Object Identifier number separated by a dot (.), in which each subsequent number is a sub-identifier. You can enter multiple OIDs by separating them with a space. Each subtree OID starts with the prefix 1.3.6.1. For example, 1.3.6.1.4.
- Type done to save your configuration.
Repeat the previous steps if you need to add more SNMPv3 views.
