PreviousNextJavaScript must be enabled to correctly display this content
Packet Trace Scenarios
This section describes three possible ways that you might use the packet trace feature. You can examine communications sent to and from one endpoint, sent between two endpoints, or sent between ingress and/or egress Oracle Communications Session Border Controller interfaces to endpoints.
