Starting a Local Packet Trace on VNF Systems
You use the start a packet trace by entering the appropriate ACLI command with these pieces of information:
- Network interface (name:subport ID combination)
(Optional) IP address to be traced; if you do not enter local and/or remote ports when you start the trace, the Oracle Communications Session Border Controller traces all open sockets.
- (Optional) Local UDP/TCP port on which the Oracle Communications Session Border Controller sends and receives traffic to be traced.
- (Optional) Remote UDP/TCP port to which the Oracle Communications Session Border Controller sends traffic, and from which it receives traffic to be traced; you cannot enter the remote port without specifying a local port.
- (Optional) Enter a tcpdump command line within quotes.
Note that the system supports local packet trace on all platforms. To start a packet trace with local and remote ports specified:
