Transcoding Support
All current platforms, except Virtual Platforms, support the same list of codecs for transcoding. VNF platforms support transcoding when you configure one or more transcoding cores.
| Platform | Supported Codecs (by way of codec-policy in the add-on-egress parameter) |
| All Acme Packet platforms |
| Virtual Platforms (with transcoding core) |
Note that the pooled transcoding feature on the VNF uses external transcoding OCSBC, as defined in "Co-Product Support," for supported OCSBC for the Transcoding-SBC (T-SBC) role. |
