SNMP/MIB Changes
This section summarizes the SNMP/MIB changes that appear in the Oracle Communications Session Border Controller version S-CZ8.1.0.
MIB Changes for EVS
This section presents SNMP changes made to support EVS.
ap-codec.mib
| Object Name/OID | Description |
| apCodecRealmCountEVS
1.3.6.1.4.1.9148.3.7.1.1.1.33 |
The count of SDP media streams received in the realm which negotiated to the EVS codec. |
ap-smgmt.mib
| apSysXCodeEVSCapacity
1.3.6.1.4.1.9148.3.2.1.1.49 |
The percentage of licensed EVS transcoding utilization (non pollable). |
| apSysMgmtXCodeEVSUtilGroup
1.3.6.1.4.1.9148.3.2.4.2.35 |
Object to monitor licensed EVS transcoding utilization. |
New Traps - New SNMP OID apSysXCodeEVSCapacity is added to transcoding utilization statistics as reported in the apSysMgmtGroupTrap. When utilization falls below 80%, the apSysMgmtGroupClearTrap is sent.
| Trap Name (clear trap) | Description |
| apSysMgmtCPULoadAvgTrap
(apSysMgmtCPULoadAvgClearTrap) |
The trap will be generated when CPU Load Average Alarm exceeds its minor alarm threshold. The clear trap will be sent when the CPU load average recedes to the minor alarm level. |
Capability MIBs
| Object Name/OID | MIB file |
| apSmgmtXCodeEVSUtilCap
1.3.6.1.4.1.9148.2.1.8.59 |
ap-smgmt.mib |
| apCodecRealmCodecCap9
1.3.6.1.4.1.9148.2.1.13.11 |
ap-codec.mib |
MIB Changes for Policy Server Objects
This table presents a policy server table miboid that is new to this version.
| apDiamRxPolicyServerStatsTable
1.3.6.1.4.1.9148.3.13.1.1.2.3 |
ap-diameter.mib |
Security-Related MIB Changes
This table lists Session agent counter and SRTP Session Agent counter table miboids that are new to this version.
| apSecuritySAIKEStats
1.3.6.1.4.1.9148.3.9.5.1 |
ap-security.mib |
| apSecuritySASRTPStats
1.3.6.1.4.1.9148.3.9.5.3 |
ap-security.mib |
MIB Changes for IMS-AKA
This table presents an IMS-AKA counter table miboid that are new to this version.
| apSipSRVCCStatsobjects
1.3.6.1.4.1.9148.3.15.1.1.3 |
ap-sip.mib |
MIB Changes for Transcoding
This table lists transcoding-related miboids that are new to this version, in this order:
- Active Transcoding Sessions
- TCU load counters
- Codec licensed capacities
| apCodecTranscodingResourceUtilMIBObjects
1.3.6.1.4.1.9148.3.7.2.5 |
ap-codec.mib |
| apCodecTranscodingTCULoadStatsTable
1.3.6.1.4.1.9148.3.7.2.6.1 |
ap-codec.mib |
| apLicenseEntry
1.3.6.1.4.1.9148.3.5.1.1.1 |
ap-license.mib |
MIB Changes for Licensing
This table presents codec miboids that are new to this version.
ap-license.mib |
MIB Changes for SRVCC
This table presents SRVCC miboids that are new to this version. These OIDs were released with S-CZ8.1.0M1.
1.3.6.1.4.1.9148.3.15.1.1.3.13 |
ap-sip.mib |
| 1.3.6.1.4.1.9148.3.15.1.1.3.14 | ap-sip.mib |
| 1.3.6.1.4.1.9148.3.15.1.1.3.15 | ap-sip.mib |
MIB Changes for TACACS
Trap Name apSysMgmtTacacsDownLocalAuthUsedTrap (ap-smgmt.mib)Trap OID 1.3.6.1.4.1.9148.3.2.6.0.88
This trap is generated when a user remotely logs into a system configured for TACACS+ authentication and is authenticated locally by the system because all of the configured and enabled TACACS+ servers have become unreachable or unresponsive.
Trap Name apSysMgmtTacacsDownLocalAuthUsedClearTrap (ap-smgmt.mib)Trap OID 1.3.6.1.4.1.9148.3.2.6.0.89
This trap is generated when a user remotely logs into a system configured for TACACS+ authentication and is successfully authenticated (i.e., access accepted or denied) remotely by a configured and enabled TACACS+ server.
MIB Changes for Voltage Monitoring
Starting in S-Cz8.1.0m1p6 and later, apEnvMonVoltageStatusValue MIB objects have been deprecated.
