Self-Provisioned Entitlements
This release uses the following self-provisioned entitlements and license keys to enable features.
This table lists the features you enable with the setup entitlements command.
| Feature | Type |
| Admin Security | boolean |
| Accounting | boolean |
| IPv4 - IPv6 Interworking | boolean |
| IWF (SIP-H323) | boolean |
| Load Balancing | boolean |
| Policy Server | boolean |
| Quality of Service | boolean |
| Routing | boolean |
| SIPREC Session Recording | boolean |
| Advanced Security Suite (JITC) | boolean |
| ANSSI R226 Compliance | boolean |
| IMS-AKA Endpoints | Integer |
| IPSec Trunking Sessions | Integer |
| MSRP B2BUA Sessions | Integer |
| SRTP Sessions | Integer |
| Transcode Codec AMR Capacity | Integer |
| Transcode Codec AMRWB Capacity | Integer |
| Transcode Codec EVRC Capacity | Integer |
| Transcode Codec EVRCB Capacity | Integer |
| Transcode Codec EVS Capacity | Integer |
| Transcode Codec OPUS Capacity | Integer |
| Transcode Codec SILK Capacity | Integer |
| TSCF Tunnels | Integer |
The following features are enabled by installing a license key at the
system,
license configuration element. Request license keys at the License
Codes website at
http://www.oracle.com/us/support/licensecodes/acme-packet/index.html.
| Feature | Type |
| Lawful Intercept | boolean |
| R226 SIPREC | boolean |
