Deprecated Features
The features listed in this section are removed from the Oracle Communications Session Border Controller beginning with the version stated.
| Feature | Description | First Deprecated |
| MSRP Stitching |
This feature, which supported peer-to-peer TCP connections for peers behind NATs, enabling Message Session Relay Protocol (MSRP) clients to communicate with one another, is not supported. Note that your can still accomplish this function using MSRP B2BUA. |
SCZ8.0.0 |
| Telnet |
Telnet is not supported. Use SSH for network access to OCSBC management. Note that references to Telnet and FTP are still present in the S-CZ8.0.0 documentation set because those terms are still used in the ACLI. For example, the telnet-timeout parameter persists in the guide because it persists in system-config. In the absence of Telnet support, the telnet-timeout parameter now sets the SSH timeout. |
SCZ8.0.0 |
| ACLI "management" Command |
The management command is not supported, and removed from the ACLI. |
SCZ8.0.0 |
| The dynamic-trusted-drop-threshold Feature |
The media-manager-config's dynamic-trusted-drop-threshold feature is not supported, and the parameter is removed from the ACLI. |
SCZ8.0.0 |
| Acme Packet 3820 and 4500 |
This version of software does not support the Acme Packet 3820 and the Acme Packet 4500 platforms. |
SCZ8.0.0 |
| The phy-link redundancy Feature |
The phy-interface's phy-link redundancy feature, which was available on the Acme Packet 3820 and 4500 platforms, is not supported. The parameter is also removed from the ACLI. |
SCZ8.0.0 |
| The minimum-reserved-bandwidth Feature |
The access-control's minimum-reserved-bandwidth feature, which was available on the Acme Packet 3820 and 4500 platforms, is not supported. |
SCZ8.0.0 |
| TLS Ciphers |
SCZ8.1.0 |
| secure-traps |
Within the context of the OCSBC's comprehensive SNMPv3 support, the secure-traps value is removed from the snmp-agent-mode parameter. In addition, the elimination of secure-traps means that the following protocols are deprecated for use by SNMP:
SCZ8.1.0 |
| apEnvMonVoltageStatusEntry MIB object | The apEnvMonVoltageStatusEntry objects have been deprecated. Voltage monitoring is still available using the show voltage command in the ACLI. | SCZ8.1.0m1p6 |
The following features were deprecated prior to this release.
| DES-CBC Ciphers |
The OCSBC deprecates the following ciphers, adhering to recent OpenSSL changes intended to eliminate weak ciphers:
The user should remove any prior Oracle Communications Session Border Controller version configuration that used these ciphers, and not configure a security profile with the expectation that these ciphers are available. Note also that TLS profiles using the ALL (default) value to the cipher-list parameter no longer use these ciphers. Note: Your version of the ACLI may still prints these ciphers when you run cipher-list ?. Despite printing them in ACLI output, the system does not support them within service operations. |
SCZ740m1 |
| FTP Support |
The OCSBC's FTP Server is not supported. Only FTP client services are supported. For example, FTP client service for HDR/CDR push is supported. Note that both the SFTP client and server are supported. |
SCZ7.3.0 |
| MGCP Signaling Support |
MGCP Signaling is not supported. |
SCZ7.1.2 |
| SIP Monitor and Trace / WebGUI |
The SIP Monitor & Trace and WebGUI features are not supported. |
SCZ7.2.0 |
| Source-based Routing |
The source routing feature as configured by system-config, source-routing is not supported. Please review the HIP information in the Network Interface section in the System Configuration chapter of the ACLI Configuration guide for background on accessing OCSBC Administrative Applications over media Interfaces. Note: Despite deprecation, the parameter is still present in the system-config. |
SCZ7.1.2 |
| H.248 |
The Border Gateway and H.248 functionality are not supported. |
SCZ7.1.2 |
| HMR action on Call-ID |
HMR operations on the Call-ID: header are not supported. |
Prior to SCZ7.1.2 |
| Session Replication for Recording |
Session Replication for Recording is not supported. |
Prior to SCZ7.1.2 |
| MIKEY key management protocol |
Multimedia Internet KEYing (MIKEY) for SRTP |
SCZ7.1.2 |
| Lawful Intercept Features | The following LI features are deprecated:
SCZ7.1.2 |
| FIPS Certification | Federal Information Processing Standards
(FIPS) Certification is not available in the
OCSBC.
(Note that it is available in the Oracle Enterprise Session Border Controller.) |
SCZ7.1.2 |
| IWF | Interworking Features
| SRTP |
Linksys SRTP is not supported. |
SCZ6.4.0 |
