Patch Equivalency
Patch equivalency indicates which patch content in neighbor releases is included in this release. This assures you that in upgrading, defect fixes in neighbor stream releases are included in this release.
Patch Equivalency for SCZ810
Neighbor Release Patch Equivalency for S-Cz8.1.0 GA:
- S-Cz7.4.0m1p6
The patch baseline, the most recent build from which the GA build was created, is SCZ800p2.
Patch Equivalency for SCZ810M1
Neighbor Release Patch Equivalency for S-Cz8.1.0M1
- S-CZ8.0.0p4
- S-Cz7.4.0m1p9
The patch baseline, the most recent build from which the GA build was created, is SCZ810p1.
