Verifying and Changing the Bootfile
The
check-boot-file /boot/<filename> command allows you to verify the image running on the
E-SBC.
sd225v# check-boot-file /boot/<filename>.bz Verifying signature of /boot/<filename>.bz Version: Acme Packet <release#> Beta 4 (WS Build 48) 201705130547 Image integrity verification passed
The
set-boot-file /boot/<filename> command allows you to change the image running on the
E-SBC.
sd225v# set-boot-file /boot/<filename>.bz Verifying signature of /boot/<filename>.bz Version: Acme Packet <release#> Beta 4 (WS Build 48) 201705130547 old boot file /boot/bzImage being replaced with /boot/<filename>.bz
